Air horn, which oem horn wires to tap into?
I am installing a small air horn on the gx. The relay requires a power a ground and two horn wires from the oem old horn. In our trucks there are two horns, the one on the right has two wires going into it and the one on the left has one.
Use a voltmeter to check the connectors at the horns. You'll need an assistant...
Chip H.
Chip H.
