GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Valve Cover Gasket Replacement
Old 01-11-15, 08:55 PM
nbeihl
nbeihl's Avatar
Default Valve Cover Gasket Replacement
Has anyone done a valve cover gasket on this car? Both of mine are leaking a little bit (185,000 mi) and I can smell the oil burning when it drips onto the exhaust manifold. I was going to give it a shot and I was wondering if there were some instructions anywhere.
Old 01-14-15, 09:43 AM
cdew002
cdew002's Avatar
I had the same issue - 195k miles. It looks fairly straightforward, but time consuming.
I say "had" because I actually tightened the valve cover bolts and the leak stopped. May want to give that a shot first. A lot of mine were loose to the point that I could tighten it more with my fingers...
Old 01-14-15, 09:52 AM
470SNC
470SNC's Avatar
Common issue, just tighten down all the bolts and should stop the leak
Old 01-19-15, 09:21 PM
nbeihl
nbeihl's Avatar
You guys were right, every one of my valve cover bolts were not even hand tight. I tightened them up. I'll bet that works! Thanks for the info!!!
rscpa
RX - 4th Gen (2016-2022)
01-24-18 12:57 PM
LexBrett
Maintenance
03-31-15 09:40 PM
dquach89
GS - 1st Gen (1993-1997)
15
07-11-11 07:20 PM
Pheonix
12-18-08 11:41 AM
gerbjones
12-08-02 11:18 PM
Quick Reply: Valve Cover Gasket Replacement
