Rear Airbag Suspension Question
Hi All -
We are going to look at a 2003 GX470 tomorrow with 80K miles on it. A quick question on the rear airbag suspension. How do I determine if it is operating correctly? I read a couple posts that state the rear end with rise up with the car is started. Also, I read there is a control within the cabin to raise and lower the vehicle (i.e. the rear end) manually. Is this correct? One last question, I have read a lot of posts about replacing the airbags with coils. Is it just a matter of time before the airbags go out?
Thanks for any help,
Stoshzack
Stoshzack
From what I've seen, when leaks in the air suspension occur, it's 50:50 between the bags and the air lines/compressor fittings.
Chip H.
So, I have posted before on this issue..replace entire rear suspension, air bags, height sensors, solenoid reservoir. Truck still has a slight tilt to the drivers side. Measured distance from ground to center of rod bolt, 111/2 inches drivers side, 12 on passenger. Looks worse when Looking at the bumper from behind. So out of curiosity I raise the height sensor to its limits in the slot..on drivers side....take it for a ride...drivers side now 11 7/8, passenger side 12 3/8. Both sides went up 1/2". You would think the sensors were independent , right?
