GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Do I need Resistor for LED Signal Lights
Old 11-03-12, 12:20 AM
guccigucci
guccigucci's Avatar
Default Do I need Resistor for LED Signal Lights
I have come across some threads saying that if we switch our front turning signal bulbs we need resistors, some say we don't. So yes or no? I have come across these bulbs that I wanna get from ebay
http://www.ebay.com/itm/1156-1156A-1...c8d776&vxp=mtr
So do we need resistors or just buy these bulbs and plus and play?
Old 11-03-12, 05:35 PM
tz693
tz693's Avatar
No, you don't. These LED bulds are designed for 12V PnP. They already have resistors on the back of the LED arrays.
Old 02-01-13, 06:38 AM
vince22
vince22's Avatar
No worries...this one has built-in resistor / no hyper flash........
http://store.ijdmtoy.com/No-Resistor.../canbus-2g.htm
Old 02-02-13, 08:50 AM
mann777
mann777's Avatar
By doing a simple mod on the flasher by adding a trimpot, it does wonders and you can LED to every side of GX wherever you want without thinking about any resister.
Here is what I did
Used a Burn Trimpot
Cost - $3
Time - 3 hours
Tools - Basic ones and a Fine Taper Saw file
Once completed all you have to do is turn the screw on the trimpot to the required resistance voltage and you wiull have you leds working and also your normal ones also.
The images are purely done as a passion to my GX.
Requirement - Litlle bit of Soldering knowledge to circuits boards of the Flasher Unit.
You can also purchase a new Flasher if you need to do as an additional standby kept for the original.
The images attached are buildup to the final finish.
Goodluck
Old 02-02-13, 08:54 AM
mann777
mann777's Avatar
Important Point - Note the three point on the Circuit board where these wires needs to soldered.
Old 02-02-13, 09:12 AM
mann777
mann777's Avatar
Here is the specs sheet. Multi-turn for the tolerance range from the minimum to the max..
Old 02-02-13, 07:28 PM
mann777
mann777's Avatar
Use this simple calculator for LED Resistor Resistance.
http://led.linear1.org/1led.wiz
http://ledcalc.com/
Old 02-26-18, 08:20 AM
thehundred
thehundred's Avatar
sorry to bring this thread back up, will those solder points work on original OEM flasher 12pin (81980-50030) or only on 8 pin(81980-50030) version?
doodlebug
06-01-16 05:37 AM
14blk250a
08-26-14 01:41 PM
RudeDoggy
General Classifieds
07-10-13 06:06 AM
whytry
11-01-12 02:34 PM
thirdmotio
Lighting
22
07-28-05 09:29 PM
Quick Reply: Do I need Resistor for LED Signal Lights
