Dimming Nav screen at night
Is it me or does the Nav screen not dim at night when you turn the headlights on? Is there a way to do this, or do I just have some setting not set right. Any help would be welcome. Thanks.
Dash dimmer control
At night it will switch from a white background to a dark back ground. This is controlled by the dash dimmer control, lower left of the steering wheel. If turned all the ways up it disables the change over. If turned down a little the background switch will happen when the headlights switch on.
