GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Plastic pop rivets
Old 09-07-05, 05:45 AM
db6
db6's Avatar
Default Plastic pop rivets
Whats the correct way to open the fuse box under the hood? There are plastic pop rivets holding down the cover.
Thanks
Old 09-07-05, 09:41 AM
CdeFabio
CdeFabio's Avatar
Just use a small phillips screwdriver and push down on the center part of the rivet, you should be able to lift it out easily. Then to put it back in, push the center part back up and put the rivet back in the hole and push the center part back in to lock. Hope that helps.
Old 09-09-05, 08:03 AM
LvMyGX
LvMyGX's Avatar
Are you having a problem with a fuse blowing?? Because I am!!
Old 09-09-05, 08:50 AM
db6
db6's Avatar
Default no problem with fuses, I was looking for a place to
hardwire a valentine one from
jbrittmart
07-08-16 06:59 AM
ahde
05-18-16 07:34 PM
carlos
11-06-07 11:09 AM
Quick Reply: Plastic pop rivets
