Rims/tires help
Subscribe
Sep 9, 2022 | 10:40 AM
Hey just pick up an 07 and I’m trying get the build going. I’m having trouble with rim/tire choices. What I have so far is RRW RR7-H rims but what I can’t decide on is the offset. Either -12 or -25. I’m looking to fit 35s. I do have a kings 2.5 remote res front/rear coming. I’m looking for a functional aggressive stance with not a. Crazy amount of poke
Reply 0
Sep 9, 2022 | 03:46 PM
Better to be as close to zero offset. More neg means more swing (more radius from the spindle). If it can pivot near zero w/o hitting anything, that's the better choice.
But, with 35's, not really sure if a -25 is needed or not. Pros & Cons. Have a local shop do a fit test of each.
Reply 0
Sep 9, 2022 | 08:38 PM
If you're planning on fitting 35's, then wheel sizing/specs is dependent on how you intend to make the tires fit. Too many factors for anyone to really tell you what you should order here. The shop doing the install should probably work with you to figure this out.
Reply 0
Subscribe
