excessive heat
Old Jun 1, 2022 | 08:18 AM
mjweston61's Avatar
mjweston61
Default excessive heat
All of a sudden, there is excessive heat from under our 2004 GX. the center console is hot and an item actually melted that was sitting on the carpet in the middle of the vehicle. the back of the driver seat is warm as well
we just replaced serpentine belt and repaired a pulley tensioner but wondering if it could be bad cat converter?
puzzled
thanks
mike
Old Jun 2, 2022 | 06:44 AM
Khartig's Avatar
Khartig
puzzled
thanks
mike
It could possibly be a bad cat. Normally if they're that bad it will throw a code, but we have had a couple car in our shop with cats that actually get red hot and not cause the CEL to come on.
Old Jun 2, 2022 | 01:25 PM
chiph9's Avatar
chiph9
Bad cat would also be my guess. Also check your EGR valve (and oil level) for a possible cause if you find it's running cherry red. A bad valve can suck in oil and cause the engine to run rich, overheating the cat.
Chip H.
Hoovey689
Feb 13, 2012 08:59 AM
mr29rose
Aug 25, 2009 01:19 AM
black04gx
GX - 1st Gen (2003-2009)
May 2, 2009 08:14 AM
pemarsh
Aug 11, 2007 10:07 PM
