Auto lock question 2009 GX 470
Subscribe
Nov 14, 2020 | 12:41 PM
Does anyone know if you can disable the doors locking when the key gets a certain distance away/ Drives me NUTS
sorry, 2009, not 2209 lol
Reply 0
Nov 14, 2020 | 12:52 PM
I think you need an ODB port reader that allows for the adjustments.
Reply 0
Nov 17, 2020 | 11:27 AM
Your doors lock when key rfid gets some feet away from the ignition ring?
Reply 0
Nov 17, 2020 | 04:04 PM
Yeah, you're probably going to need the Techstream software for this.
BTW, when you get home, put your keyfobs in one of those Danish butter-cookie tins so that thieves can't clone the signal.
https://www.wcnc.com/article/news/cr...3-f86de1faafea
Chip H.
Reply 0
Nov 17, 2020 | 04:50 PM
Originally Posted by Kbach View Post
Got this fron the dealer the other day. You can set the following auto door locking and unlocking functions. All times must be EXACT or it will not work.
(a) Locking linked with the shift position
All the dooor are locked automatically when the selector lever is moved out of the "P" position with the ignition switch in the "ON" position. This is suppose to be the default setting for new vehicles.
(b) Unlocking linked with the shift position
All the door are unlocked automatically when the selector lever is moved to the "P" position with the switch in the "ON" position.
(c) Locking linked with the vehicle speed
All the doors are automatically locked when the vehicle speed reached 12 mph or higher. However, if any door is unlocked during driving, the auto function will not operate until the unlocked door is opened once.
(d) All the doors are unlocked automatically when the driver's door is opened within 10 seconds after the ignition switch is turned from "ON" to the "ACC" or "LOCK" position.
Setting the functions
1. Close all the doors.
2. Turn the ignition switch to the "ON" position.
3. Within 10 seconds after the ignition switch is turned to the "ON" position;
+To set function (a)
Push and hold the front of the power door lock switch for 5 seconds with the selector lever in the "P" position.
+To set function (b)
Push and hold the rear of the power door lock switch for 5 seconds with the selector switch in the "P" position.
+To set fuction (c)
Push and hold the front of the power door lock switch for 5 seconds with the selector switch in any position except "P".
+To set function (d)
Push and hold the rear of the power door lock switch for 5 seconds with the selector switch in any position except "P".
All the doors are automatically locked and unlocked when you release the power door lock switch. This indicates that the functions is set. If all the doors do not lock and unlock, the time the switch was held may have been too short or too long. Perform the procedure over again starting at step 1.
If you want to cancel a function, repeat the procedure.
Reply 0
Nov 17, 2020 | 05:32 PM
Post #5. Yeah, those are in Techstream. I do not see a setting for auto-lock when the key gets too far away for ignition ring to read it.
Honda has this feature, I don't think Toyota has it on any vehicle in the US. I saw some chatter about it being on some Toyota vehicles in other markets.
Reply 0
Subscribe
