bouncy air shocks
Old Apr 16, 2020 | 09:59 AM
muldowney2's Avatar
muldowney2
Default bouncy air shocks
Just had the GX aligned at NTB, then went across the street to Lowe's and took home a fair load of 8 concrete pavers. The ride was incredibly bouncy and uncomfortable. Not sure if this was the result of the heavy load or something that occurred during alignment. Anybody have a similar issue? Thanks.
Old Apr 16, 2020 | 11:22 AM
IanB2's Avatar
IanB2
Probably bouncing off the bump stops with the heavy load in there, if it's still loaded crawl under and see how much space between the rear axle and bump stops (just inboard of the rear tires).
Old Apr 16, 2020 | 11:56 AM
captainva's Avatar
captainva
The rear airbags are not actually shocks. They are where the springs would be in the truck if it had springs instead of airbags. Worn out rear shock absorbers that can't deal with the amount of force moving up and down due to the added load are more likely the culprit if the truck rides the same when you unload it.
Old Apr 16, 2020 | 04:40 PM
se7enine's Avatar
se7enine
The weight is making the blown shocks more noticeable.
Old Apr 17, 2020 | 06:22 AM
captainva's Avatar
captainva
TLDR: Yes this
Jonx
May 6, 2020 07:12 PM
Siven
GX - 1st Gen (2003-2009)
May 1, 2018 05:57 PM
2gs4u8
Sep 29, 2011 02:10 AM
jac430
Jun 14, 2011 08:35 AM
chemical44
Mar 15, 2010 12:32 PM
