Door locks 2004 gx
Old Jan 13, 2019 | 04:24 PM
wow2003gx's Avatar
wow2003gx
Default Door locks 2004 gx
Good day all
my wife’s car has an odd on off again traveling door lock issue. One day all work next day passenger will not unlock. Few weeks later all workbut, the drivers. Now the drivers and rear hatch tot working. ( rear hatch was stuck locked ) after using passenger side switch it’s now unlocked but will not lock.
Where red should I start? Thanks in advance
Old Jan 14, 2019 | 06:48 PM
chiph9's Avatar
chiph9
It's unlikely that all the actuators are going bad at the same time. I would look for a failing battery to start. If it's good, I would do a computer reset by disconnecting the negative terminal, wait 2-3 minutes, then reconnect it with a minimum of sparks (you will need to reset the auto-windows, radio stations, etc. afterwards - see the sticky about it)
Chip H.
foreste1
GX - 1st Gen (2003-2009)
Jan 23, 2022 05:34 AM
visionar
Apr 8, 2017 07:31 AM
donner454
RX - 1st Gen (1999-2003)
Oct 17, 2016 07:25 AM
Rx900
Aug 29, 2005 04:22 PM
