2006 GX 470 wheels vs 4 runner wheels
Old Dec 28, 2018 | 03:52 AM
JeffLee's Avatar
JeffLee
Hi,
Nice looking truck.
Could you tell me what size tire you're using with those wheels? I just bought a set for my GX and wonder if the 265/70/17 tire will fit appropriately.
Thanks.
Old Dec 28, 2018 | 07:44 AM
JSC4's Avatar
JSC4
Originally Posted by JeffLee
Hi,
Nice looking truck.
Thanks.
​​​​​​​4Runner wheels will fit and actually look better due to slightly taller sidewall 265/70/17. So no issues there.
You can fit 275/70/17 on GX470 stock height without any issues. Anything larger will have to be modded. (Trim bumper, remove running board etc.)
Some people on IH8MUD said 285 can fit with little mod. Some said only rubs on full turn. I personally would go with 275 to be safe.
Of course, these also depends on the car's age and how the suspension is.
Old Dec 28, 2018 | 08:15 AM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
Those 4Runner wheels look good.
Old Dec 28, 2018 | 09:23 AM
JeffLee's Avatar
JeffLee
Thank you. In the photo of your truck are those tires 265 or 275? I don't know tires but if I understand you correctly a 275 is just a little taller and wont create any rubbing issues. I was originally concerned about the offset but that apparently wont be a problem with the wheel rubbing the caliper. Thanks again.
JeffLee
Old Dec 28, 2018 | 11:14 AM
Arailt's Avatar
Arailt
JeffLee
Hey Jeff, I have 275/70r17s on my stock height GX. They are 32.2” by 11” vs 30.5” by 10.4” factory spec tires. I mounted them on 4Runner TRD Pro wheels that have a +4 offset vs the +25 offset of factory GX wheels, so they sit about an inch further out from the frame than factory wheels would. I did have to move the front wheel well liner forward ~2” to accommodate the 275. If I had not done that, the tires would have rubbed on the plastic liner.
edit: I also removed my running boards and installed sliders. Trimming the running boards would probably be required to clear the 275s.
Here’s a bad picture of the fender liner mod. You can’t really tell from this angle, but there’s only about .5” of clearance after I moved it forward almost 2”. Maybe if the whee offset was closer to factory, the tires wouldn’t be that close to the liner. I’m not sure.
Old Dec 28, 2018 | 03:50 PM
JeffLee's Avatar
JeffLee
Seems like the 275 may, potentially, require some mods. My GX is a 07. 275 may clear, may not. I like it just the way it is :-) No plans to off road. However, with all the rain we're getting here (MD) the off-road may be coming to me. Your info was very helpful. Thank you.
JeffLee
Old Dec 28, 2018 | 04:26 PM
Arailt's Avatar
Arailt
Haha. If you don’t need bigger tires and don’t plan to go off road, I would stick with 265/65s that come factory or maybe up one size to 265/70 for looks. 275s are significantly bigger than stock and in my experience, will not fit without some minor trimming. In 275/70r17, it’s tough to find an AT/MT tire that isn’t load range E, so mine are very heavy and the ride has changed considerably as a result.
Old Aug 30, 2020 | 06:01 PM
justfortun's Avatar
justfortun
anyone know if the my 2006 GX lug nuts will fit 2019 tacoma wheels?
Old Nov 22, 2020 | 09:52 AM
DanO470's Avatar
DanO470
Default Tires
Originally Posted by JamesF
I just put these in my 2006. Found them brand new for $200. The problem is finding a single for the spare at a decent price. Fitment is perfect.
what size tires and did it impact your speedometer?
DucatiKing
GX - 1st Gen (2003-2009)
Jan 15, 2018 05:43 PM
Matsui
Oct 21, 2015 05:39 AM
pbsabo
GX - 2nd Gen (2010-2023)
Apr 24, 2014 07:51 AM
bobinsofla
16
Feb 5, 2008 03:18 PM
