Metaltech or arnott rear coils
Old Oct 5, 2017 | 11:50 AM
DBPrado120's Avatar
DBPrado120
Default Metaltech or arnott rear coils
Hi Guys, I am looking to convert my Prado 120 VX 3.0 Diesel from air to coils. Looking to keep the height stock and keeping the OEM rear and front in place. I have been searching the net to find the best possible conversion kit that fits what I am looking for. My bags failed and got rid of the system. I am dont do any towing nor do I load up 600lbs of bricks in my trunk. I am looking to get as close as possible to the original ride quality pre-airbag failure. Can anyone suggest which brands would make the most sense in my case? Metaltech or Arnott? Who has done the conversion with any of these brands and how is the ride quality? Oh any BTW I dont do any off roading either
Old Oct 5, 2017 | 01:07 PM
Goosed's Avatar
Goosed
Someone will come in here and say do a search, there is a lot of info already. But I am also in the same boat as you. What would be good to specifically know is if there is a kit out there that DOESN’T lift the rear. Have read a lot of threads that show after pictures where the **** end of the GX is sitting much higher than the front, which is worse than before the conversion.
Anyone out out there have luck retaining all stock height in the rear with a coil conversion? If so, what was your set up and post a pic to review... I have one bag going bad and know to replace in pairs, figure going coils may be a good choice now.
Old Oct 6, 2017 | 06:53 AM
IanB2's Avatar
IanB2
I'll be doing the conversion with the SSO kit and FJC rear springs, keep an eye open for the results in the next few weeks. I'll take some before/after measurements and pics.
Old Oct 6, 2017 | 07:33 AM
Goosed's Avatar
Goosed
will stay posted. Interested to see the results. If possible, could you measure the rear height (from ground to center wheel well) before and compare to after?
Old Oct 6, 2017 | 03:42 PM
maxx430's Avatar
maxx430
I would love to see the result as well. My rear suspension starting to make a clunking noise over bumps and the rear is harsh going over bump as well.
Old Oct 13, 2017 | 10:12 AM
bkingsle8's Avatar
bkingsle8
10th Gear
Once you do the conversion, if the springs are too high, order KYB factory 4runner springs and use those - should work.
Last edited by bkingsle8; Oct 13, 2017 at 10:17 AM. Reason: Edit - saw that you don't plan on towing anything - ever.
Old Oct 20, 2017 | 06:42 PM
customdave's Avatar
customdave
Hello, I just put the MetalTech stage 3 coil conversion kit on today. Went ok. I ended up taking the sway bar end link mounts off and the shocks to get the rear end to drop enough so I didn't need to use a spring compressor. Ride quality is pretty good with the springs. The ride height I feel is a bit lower in the rear now. I found a leaking rear shock so that might have something to do with the height too. Here are some pictures, wish I had more but I was pretty dirty today.
Attached Thumbnails Metaltech or arnott rear coils-img_20171020_142430719.jpg   Metaltech or arnott rear coils-img_20171020_151148072_hdr.jpg
Gfat87
GX - 1st Gen (2003-2009)
Oct 15, 2018 07:16 PM
enriquerrs
Aug 7, 2017 01:13 PM
seivonecsu
Suspension and Brakes
24
Sep 24, 2012 07:43 PM
Smileyboy
Mar 19, 2012 04:33 PM
flektone
Jun 19, 2011 05:34 PM
