Driver Side Dash/Steering Assembly Squeak/Clink?
Old Jul 30, 2016 | 09:21 AM
6rga226's Avatar
6rga226
Default Driver Side Dash/Steering Assembly Squeak/Clink?
Hello!
I have been searching on the forums for potential causes for this annoying squeak/metal clinking noise coming from the driver side dash/steering assembly. The sound only activates past 30 mph and gets agitated over bumps in the road. I've posted a video of the noise and am wondering if anyone can point me in the right direction as to what is at fault? Thank you in advance!
James
Old Aug 1, 2016 | 04:00 AM
DAKONA's Avatar
DAKONA
Kinda hard to tell what it is.
Key chain tapping the dash or hitting the key reason ring?
DAKONA
Old Aug 3, 2016 | 08:53 AM
6rga226's Avatar
6rga226
I was hoping that would be the case but I made sure nothing obvious was causing the noise (keys, items in cup holders or in door storage). Ive isolated the sound coming from the dash, steering column, or steering wheel. It almost sounds like a bolt or washer is loose and hitting against another metal object. Any other thoughts?
Old Aug 3, 2016 | 09:35 AM
180ls1's Avatar
180ls1
Seems like one of those things thats almost impossible to figure out without ripping it apart. I dont have a good suggestion besides that.
Old Mar 10, 2023 | 03:11 PM
Mlad's Avatar
Mlad
1st Gear
Any chance you solved or found the source of the Squeak? I have the exact same one and it is driving me nuts!!
Thanks in advance for any suggestions!
xfea
Aug 9, 2021 10:20 AM
EyeKutr
Sep 29, 2007 07:24 AM
purebliss
Jun 27, 2006 06:25 AM
