Front caliper piston won't retract
Old Mar 23, 2016 | 11:28 AM
john689089's Avatar
john689089
Default Front caliper piston won't retract
After getting the front caliper off, I retracted the outboard pistons using the old brake pad and a C clamp. When I tried to retract the inboard pistons, the top piston retracted just fine with the old brake pad and C clamp, but the bottom piston will not retract. I have opened the bleed valve and squeezed the bottom piston with the C clamp as hard as I could, but it will not budge. With the one stuck piston, I cannot replace the inboard brake pad. Any ideas? Am I going to have to replace the entire caliper?
Old Mar 23, 2016 | 11:37 AM
co4wheel's Avatar
co4wheel
Your going to need to rebuild the caliper or replace it. The piston and cylinder is damaged. It won't work.
Old Mar 23, 2016 | 12:28 PM
john689089's Avatar
john689089
Thanks co4wheel. That's what I was afraid of. I assume it's best to replace both left and right calipers at the same time? Is there anything special about replacing the calipers? I know you have to bleed the brakes lines after getting everything back together.
Old Mar 23, 2016 | 12:49 PM
co4wheel's Avatar
co4wheel
Nay, should be easy enough.
Old Mar 24, 2016 | 09:06 AM
IanB2's Avatar
IanB2
I'd replace only the seized caliper, as it's the only one with an issue. I'm all for overkill, but if it ain't broke...
Old Mar 24, 2016 | 11:36 AM
180ls1's Avatar
180ls1
Exactly, just fix the damaged one.
wsrivers
Jan 16, 2018 12:52 PM
Gx470blk
GX - 1st Gen (2003-2009)
13
Sep 20, 2016 10:56 AM
shivam
May 17, 2013 06:28 AM
atl530i
Jul 9, 2012 08:49 PM
pinoybboy
May 2, 2006 03:51 AM
