Howto: Replace the headlights
Old Mar 3, 2021 | 07:03 PM
se7enine's Avatar
se7enine
If you're comfortable opening up the headlights you can modify the stock projectors for great results. XD H11 HID bulbs
Old Mar 4, 2021 | 07:15 AM
offroad200's Avatar
offroad200
I'm gonna be that guy that says to never put in HIDs or LEDs in halogen housings. Yes you have a projector but it's designed for halogens, not HIDs. Yes they are very bright but you run the risk of blinding every oncoming car with glare. Don't be that guy. There are no true H11 HIDs. They are rebased to fit. If you want to run HIDs, do a proper retrofit with projectors designed for HIDs.
Or as mentioned run H9s in the low beams and 9011s in the high beams. Both are halogens so no issues with glare and are about twice the lumens of stock bulbs while properly putting the light where it's mean to be.
If you want to go down the rabbit hole, read this thread.
https://www.tacomaworld.com/threads/...lights.589465/
Old Mar 4, 2021 | 08:37 AM
Jpilot's Avatar
Jpilot
Great info, I agree 100%.
Old Mar 4, 2021 | 12:17 PM
se7enine's Avatar
se7enine
It's modified. There is no difference in the stock Koito vs a Koito designed for HID other than bulb holder, cutoff design and lens spacing. The cutoff has been modified to be exactly as a HID cutoff. That's why there isn't any light above the cutoff.
Old Mar 4, 2021 | 12:33 PM
offroad200's Avatar
offroad200
That works! Because (as you already know) a non modified halogen projector isn't able to handle the tremendous amount of light going about the cutoff (uplighting?). Do you have a link on how the projector is modified? I still want to do a retrofit one day with RX350 projectors so I can run HIDs that haven't been rebased (not that a rebase is always bad).
Nguyen250
Aug 7, 2016 11:52 AM
rayray9414
Jan 8, 2015 10:58 AM
99rx
RX - 1st Gen (1999-2003)
Feb 9, 2011 04:38 AM
CAsclover
Jul 1, 2010 09:51 AM
