Old Dec 12, 2014, 03:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
changing front shock absorber on GX470
Old Mar 14, 2017 | 08:05 PM
  #31
2008's Avatar
2008
Could easily be a wheel speed sensor (ABS sensor). Hopefully the cable itself isn't damaged but wouldn't be too hard to imagine. If you pull the code off of techstream it'll tell you what's up. I accidentally cut my front left wheel speed sensor when switching out the shocks. Had to repair it (quicker and less $ than ordering the part online) which was not bad. No issues almost 10k miles later.
Old Mar 15, 2017 | 07:43 AM
  #32
jasanders's Avatar
jasanders
I had a guy do the installation for me. Should he have left the sensor that was on top of the old shocks attached to the wire? We disconnected that from the wire and left it on top of the old shocks after they were taken out.
Old Mar 16, 2017 | 07:49 PM
  #33
2008's Avatar
2008
The wire attached to the struts is for the adjustable ride .. you leave it disconnected if replacing with non-adjustable struts. That won't cause lights to come on the dash. It will cause a code in techstream saying they're disconnected but not a big deal. With the front struts you have to wire tie the wires that attached to the struts somewhere out of the way for safe keeping. With the rears it's a non-issue (rears have a wire that goes into a frame mounted plug so nothing to wire tie).
Long story short you have an issue other than adjustable ride wire. My guess is wheel speed sensor was disturbed or damaged. This can happen when the caliper is not hung up properly and stress was put on the sensor/wire.
Old Jul 26, 2017 | 11:35 AM
  #34
Butcherpen's Avatar
Butcherpen
10th Gear
Default Botton Stuck
Bottom
After I got all the bolts out it still wont come off. It is compressing down and the bottom mount wont come out..even with a hammer. Do I need to compress the coil spring with a tool?
Old Jul 26, 2017 | 11:52 AM
  #35
SC3coupe's Avatar
SC3coupe
Originally Posted by Butcherpen
Bottom
If you use a pry bar put in one of the round holes in the control arm, then you should be able to put some weight on it, ( most of your weight.. ) to free the shock.
You may need to lightly pry the bottom of the front shock so it would pop out. Some people have the top mount stuck on the top too. It is not clear what your problem is, can you tell which part is already free? You should be able to see a gap off the top mount when you pry the control arm down.
Old Mar 2, 2018 | 02:32 PM
  #36
hochiminh's Avatar
hochiminh
Originally Posted by Ali SC3
Yeah I went back out there today after letting it soak all night, it still did not want to come off =(
I got a crow bar wedged at an angle between the top plate and the mount, and got the biggest hammer I had and went to town on it ( i tried same last night but with alot less force).
well on the 5th large hit the shock just fell down, so it was just dirt and grime holding it in place which is seriously the strongest I have ever encountered.
so thanks for the suggestion guys, it turned out to be a simple problem that needed a bigger hammer, or as I call it "suspension adjustment tool"
Man, I'm having the same issue removing the top hat. Where did you wedge the crowbar??
Old Sep 18, 2020 | 07:28 PM
  #37
Shalmanese's Avatar
Shalmanese
Originally Posted by Sdgx470
It's my first time working on my 2005 GX470 to change the front shock absorber. Have some questions on how to correctly and safely change it. Would appreciate your advice on the following:
1) To remove the strut assembly, do I need to remove the sway/stabilizer bar?
2) I have already removed the lower strut bolt, but got stuck on the top part. Should I remove the absorber control actuator and its bracket first (by removing the two nuts at label #3 in the attached photo)? It's not easy to get to these nut and seems like it's round. What tool to use for removing #3? There are two #3s, how to remove the on in the back?
3) how to disconnect #4? Or I can leave it connected?
4) should I loosen nut #2 to help remove the strut or the actuator? Is this the one that is holding the spring in position and loosen it without using the spring compressor is dangerous?
5) Also, it's hard to reach the third nut in the back (labeled as 1 with dashed arrow). So have to remove the bracket first?
Thanks for your help.
I'm tearing down my shock absorbers for replacement. What's the thread count & size of the suspension control mounting bracket 4MM hex bolts? I'm assuming I'll strip them all and will pick them up before I get started. I might even pick up something with a stronger head! Viva le ratchet wrench!
Old Sep 20, 2020 | 08:03 AM
  #38
Shalmanese's Avatar
Shalmanese
Originally Posted by RCsGX
I'm attaching a PDF that shows step by step how to remove the OEM coilover. Good luck and remember to torque everything back to spec when finished.
*torque specs are in the PDF*
Great PDF, thank you! It sez it's repair manual at the end, but no publisher/author. Do you remember?
Old Jul 20, 2021 | 07:09 PM
  #39
gman71's Avatar
gman71
Can anyone identify the part # for the actuator bracket? I need to replace them on both sides but can't even find the bracket in a diagram online. I'm stumped.
Old Jul 21, 2021 | 06:31 AM
  #40
se7enine's Avatar
se7enine
What bracket do you need? I just converted to Dobs and don't need the sensor for the front coilovers but kept them in case someone needed them.
Old Jul 26, 2021 | 11:31 AM
  #41
gman71's Avatar
gman71
Default Bracket
It's the bracket that holds the electronic actuators on top of the strut. I have two, but they're bent, rusted, and are missing every plastic cable-retainer clip.
Old Jul 26, 2021 | 12:37 PM
  #42
Lexus4321's Avatar
Lexus4321
There's an LH and RH for it (89269A). It's a shared part # for many Toyota made vehicles.
Old Jul 27, 2021 | 06:34 AM
  #43
se7enine's Avatar
se7enine
If you want a pair cheap with the sensors still attached then I'll sell you mine cause I don't need them.
Old Jul 28, 2021 | 06:28 AM
  #44
se7enine's Avatar
se7enine
Old May 20, 2024 | 07:30 PM
  #45
quick6's Avatar
quick6
1st Gear
This thread is really helpful -- thanks all!
QQ: I'm replacing the front shocks with new OEM units -- do I need to index the adjusters before removing and installing the new ones? E.g. I don't want to create a situation in which the in-vehicle **** is set to "sport" but the shocks are on "comfort" when I install.
Any advice would be appreciated!
ETA -- ah never mind. I think I figured it out
396chevy
14
Jan 30, 2020 09:23 PM
kuziwk
Oct 23, 2010 09:37 PM
RyanV
Dec 31, 2009 07:25 PM
IStrip50
Suspension and Brakes
Jun 18, 2009 09:13 AM
WILB3
Sep 10, 2003 01:17 PM
