Console mounted power socket
I had the spring loaded cover on the power socket snap in half . I don't like leaving it open. To easy for something to fall in coins etc. I went on line and looked on sewel cant find a picture of it and I don't want to confuse it with the rear 110 volt passenger port. I need to replace it . I also need to know if there is a simple way to remove it from the front. I don't want to start to have to pull the top of the console and start pulling the wood panels off. Last time I had the wood panels off the clips are in bad shape and I don't want to mess with them. I thought there was a way to remove the power socket by pulling on it. I don't want to stress it unless this is how you can remove it. Can some one advise 2004 gx470
Buddy
I think the socket is called " Power Point " [ Its to the left of the seat heater switches ]
Buddy
The cover OEM part number is: 8553560050C0
Sewell sells it but they don't show a diagram:
PNC: 85535B
http://lexus.sewellparts.com/oem-cat...X470-2004.html
Here's a eBay link to show it is the correct part and by the time you add $10 from Sewell the eBay seller is cheaper.
http://www.ebay.com/itm/TOYOTA-OEM-8553560050C0-Center-Console-Cover-/190945509289?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c753d3fa9&vxp=mtr
As far as removing it I'm not sure. I'd assume you'd have to remove the panel to remove it but don't quote me on that.
PNC: 85535B
PNC: 85535B
Toyota 8553560050C0 Center Console Cover | eBay
PNC: 85535B
Thanks I ordered the part I will wait till I see it to get an idea how it comes apart and maybe I can just swap out the top portion since the part pictured only looks like the top with a short insert on the bottom. Maybe someone else has taken this apart and could chime in
Buddy
DSRTWGN
GX - 1st Gen (2003-2009)
Jan 16, 2018 07:54 PM
lexnewbi
RX - 4th Gen (2016-2022)
Dec 7, 2016 03:29 PM
