Secondary Air Pump
Subscribe
Sep 16, 2015 | 05:26 AM
  #31
No sir, you do not have to unhook any harnesses in there. The bypass kit is the way to go.
Reply 0
Sep 19, 2015 | 05:15 PM
  #32
FYI for everyone.....
If you do the bypass kit module and also install the block off plates. It's surprising easy to install the block off plates. I just did it in about 15 minutes total, it took more time to jack up the truck and to remove the flats on the side of the engine. Getting to the 2 bolts for the plates was easy and luckily, they were not rusted.
Reply 0
Mar 14, 2016 | 06:25 AM
  #33
Thank you for doing that.
Reply 0
Mar 21, 2016 | 07:43 AM
  #34
I called customer service and claimed and asked for help several weeks ago. I was told that they would open a case, investigate and get back to me within 24-48hrs, I still haven't heard back from anyone. This is not the service I expect from Lexus/Toyota.
Reply 0
Mar 29, 2016 | 08:51 PM
  #35
Are there any warnings that this failure is about to occur? Like noise, etc.
Reply 0
Mar 30, 2016 | 06:35 AM
  #36
No warnings. You aren't able to hear the air pump run over the noise the engine makes.
Chip H.
Reply 0
Apr 1, 2016 | 11:16 PM
  #37
Quote: No warnings. You aren't able to hear the air pump run over the noise the engine makes.
Chip H.
Thanks Chip!
Reply 0
Dec 3, 2016 | 11:30 AM
  #38
Not entirely true, I could hear mine shortly before it completely failed and started throwing codes. Sounded like a shopvac for about 30 seconds.
I just had the secondary air pump replaced on my '05, but the indie shop that performed the work didn't inspect/replace the check vales and it threw a P1444 this morning (2 days later). I assume the failed pump blew bits of the fan into the system and messed up the (now stuck open) check valve. Question: anyone know if this is an easy (ish) fix? Does it require pulling the manifold off? I'm concerned the shop will try to charge me for this even though they should have checked the valves during the repair.
Thanks
Reply 0
Dec 3, 2016 | 03:36 PM
  #39
OK So I am
Not sure if this is the right thread.
I am having a loud Vacuum Noise coming from right passenger side. It's constant with the sound of the engine. When I rev it up it increases but doesn't go away.
A little Background.
First time it happened after I got the TB+WP+Tensioner+Pulleys replaced. I had CEL for VVT Solenoid and they troubleshooted and told me that PIN on the connecter was bent and they straightened it out and CEL went away. Regarding loud vaccum noise Service Advisor said that it was due to the Alternator running with high voltage trying to compensate for battery. Told me to change the battery. Which I didn't and the vaccum sound went away for good 6 months.
It's back now and constant from last 2 days..
Any ideas where to get started.
I can hear the noise coming from right side around the alternator area.
Reply 0
Dec 4, 2016 | 10:45 AM
  #40
The secondary air pump only runs for about 30s on cold start so I'm not confident this is the same issue you're having.
Reply 0
Dec 4, 2016 | 11:45 AM
  #41
Agree. I hope not. Plus I don't have no CEL ON just annoying. Did some investigation that sound is coming from under the intake manifold I took the filter housing out till the throttle body. Also check the suction which is very strong....
I will open the new thread and see if some one can chime in.
Reply 0
Dec 4, 2016 | 11:49 AM
  #42
Also if anyone is interested in the DIY for secondary air injection pump here is the link with all the details for GX 470.
http://www.toyota120.com/forum/showthread.php?t=28954
Reply 0
Dec 14, 2016 | 12:11 PM
  #43
So, I took the GX back to the mechanic after they replaced the air pump because it was throwing the same (similar) code (P1444). Check valve was stuck open. They replaced all three check valves (parts were nearly $500) and split the difference on labor of 5.5 hours. So ended up coughing up another $800 for a F*$@ing emissions issue. Grand total at an independent shop using Toyota parts:
$430 for genuine Toyo air pump on AMZ
$150 for Denso reman. starter (just because)
$100 in misc parts (o-rings, gaskets, coolant)
$480 for check valves
$1390 in labor
Still ended up paying $2500+ for this adventure and was without my GX for two weeks. Should have just taken it to the dealer, paid the same and had my car back in 3 days.
Merry Christmas?
Reply 0
Aug 10, 2017 | 01:09 PM
  #44
so... I went to the dealership today to get a price on the secondary air injection valve. I got the P2432 error code. So... I was talking at the parts counter and telling him about this seeming to be a pretty typical issue and service manager happened to be at the counter and he said that it's covered under the warranty no matter the mileage. I he looked up the code I gave them and he said they would have to confirm and hook it up at no charge. So I said.... let's do it. The same code came up but it was not in there system under warranty, but the apparently the whole secondary air injection system is covered.... so he's sending up the flag pole with Lexus and waiting to hear back if it's covered. But, I do remember him referring to all the codes with the air pump being covered.... P2440, P2442...ETC... So... I would DEFINITELY CHECK it out with the dealership before doing the work your self. Thanks for everyone's input on the forum. I'll let you know how it turns out.
Reply 0
Nov 16, 2017 | 02:00 PM
  #45
Question about secondary air pump
I have an 2007 GX 470 140k. I am getting the vacuum cleaner sound for 30 sec at startup. Was told by mechanic the motor is failing and $2k to repair. He said there is a 50/50 shot that if the valves or open once it completely fails I might be ok. What is the risk of doing nothing and how long do I have before the fan motor completely fails? Thanks.
Reply 0
