when to turn off height control?
Old Nov 9, 2013 | 05:28 PM
GreggyG's Avatar
GreggyG
Default when to turn off height control?
I am a little confused as to when to use this feature. Can anyone help? Thanks,
Old Nov 9, 2013 | 05:39 PM
RCsGX's Avatar
RCsGX
You turn it off if you're lifting your GX by the frame causing your axle to droop. And from how I understand it you only need to turn it off when your GX is running. If it's not running the ride height will not work so turning it off does nothing.
Old Nov 11, 2013 | 07:44 AM
ExiledWolf84's Avatar
ExiledWolf84
What he said, but i would shut it off before hand even if the car is going to jacked up with the engine off, as mine still will lower itself a bit when i get out of the car.
Old Nov 11, 2013 | 08:13 AM
RCsGX's Avatar
RCsGX
Personally I'd rather it be lower than higher since the axle will be drooping less when lifted by the frame. The more the axle droops the more chance that the airbag pin(s) will pop out of their lower brackets, so the lower the GX is on the ground before lifting the better.
Old Nov 11, 2013 | 09:59 AM
amccaulx's Avatar
amccaulx
It would be nice to be able to turn it off, and keep it off until you need it to save wear and tear.
Old Nov 11, 2013 | 11:41 AM
RCsGX's Avatar
RCsGX
EDIT: Never mind, it turns back on once you hit 20mph.
lexusflyer
GX - 2nd Gen (2010-2023)
Sep 1, 2015 06:10 PM
Sethro
GX - 1st Gen (2003-2009)
Mar 19, 2014 10:58 AM
Capirato
Maintenance
Apr 15, 2012 03:25 PM
prwdmd
16
Nov 4, 2011 07:09 AM
petsb10
Dec 11, 2005 08:41 PM
