height control
Good afternoon!!!
2003 Lexus GX470. Several months ago the height compressor assembly unit was replaced. It worked fine until few days ago when I started to experience the car going to the low position however the instrument panel indicates the control unit is in neutral with green light. The manual switch is not working either.
Any suggestions, Thanks!!!
Do you hear the air compressor running from the driver's side rear, when the truck is first started? If not, be sure to check your fuses. You can also add some weight to the back and retest. Let us know...
jayalaba
Mar 16, 2019 11:46 AM
