LED Flasher GX470
Old Sep 28, 2023 | 03:46 AM
  #46
hansaG's Avatar
hansaG
2nd gear
Originally Posted by badboys44
hi i would like to know what is the value of the potentiometer?
thanks,
samad
Bourns 3299P-1-504
3299 3/8 Inch Square Trimpot 500K Ohm 10% 0.5 W 100 ppm/°C 25(Elec)Turn Thru-Hole Tube
$ 2.48
https://octopart.com/3299p-1-504-bou...RoCkeQQAvD_BwE
Old Sep 28, 2023 | 03:50 AM
  #47
hansaG's Avatar
hansaG
2nd gear
Thumbs up
Originally Posted by mann777
Here are the detail images, they are self explanatory. All you need is good Soldering gun.
Part - Bourns Trim Pot ( 500 ampere) - Cost $2 ( P/N - 3299 )
A Cutter to cut out the plastic cover on the flasher. And a small file to trim the edges.
And Three Wire lengths - 2 inch
The next part of the set up.
Finally once done fix it back to its place and have all the bulbs replaced with LEDs and now have the trim pot adjustment done, from the lowest setting and increase it till the LEDS work. And you will never have flicker for life. All you need is patience and some time.
Seems no one is appreciating this post as it I see is the best coolest way.
This helped me with my car.
Thank you for this post!
This is from a Toyota Avanza 2006 model if it helps anyone out there.
Old Sep 30, 2023 | 09:28 AM
  #48
NickO7's Avatar
NickO7
9th Gear
Default 1156 1156a Ba15s LED Amber Yellow Bulb
I have these flasher bulbs for about 2 months. Excellent bright output and fitment:
Amazon Amazon
Old Oct 2, 2023 | 10:37 AM
  #49
cssnms's Avatar
cssnms
I installed these flasher/running bulbs which do not require an external resistor and no hyper flashing...
Amazon Amazon
So far so good.
Masteron
GS F (2016-present)
Apr 14, 2016 07:40 PM
Tonyy
NX - 1st Gen (2015-2021)
18
Apr 22, 2015 06:09 PM
ph3nxist
Feb 27, 2013 03:14 PM
Justinkm
Apr 22, 2011 01:36 PM
BinaryJay
Feb 11, 2010 09:17 AM
