GX 470 Ignition Problem
Old Dec 9, 2019 | 05:05 PM
  #31
chiph9's Avatar
chiph9
When I had my Mercedes, I used this on the outside locks to prevent them from freezing up in the winter.
Mercedes-Benz Lubricating Grease P/N 002-989-06-51-09 "Schließzylinderfett"
Chip H.
Old Jan 22, 2020 | 04:11 PM
  #32
Boltsnuts's Avatar
Boltsnuts
Default I used Lube and it worked
My gx470 2009 started not turn the key in all conditions so I sprayed inside the key hole ACF-50. I work with airplanes and this lube/corrotion eater works wonders in switches or stuff that needs lube, doesnt affect electronics if overspray. I sprayed inside the keyhole with the straw/tube and worked the key in and out not taking it all the way out and side to side then it turned, now works fine.
golfindude
GX - 1st Gen (2003-2009)
34
Jan 21, 2019 11:34 AM
acmc415
Apr 1, 2016 05:59 AM
Tipler
Aug 11, 2014 04:14 PM
lovelexus2
Aug 20, 2012 09:03 PM
rjfiore1
18
Dec 21, 2004 10:05 AM
