Difficulty replacing windshield washer hose
Old Apr 29, 2012 | 07:49 PM
sunflower's Avatar
sunflower
Default Difficulty replacing windshield washer hose
Does anyone know how difficult it is to replace windshield washer hose? I need to replace the entire hose system starting at the washer reservoir to both front and rear windshield wipers.
A MOUSE ate my washer hose! GX washer hose is soy based which apparently appeals to rodents. Evidently this is not terribly uncommon, soy based hose/rodent delicacy plaques a few Volvos and Honda models as well.
I’m trying to determine if I need to take it to the dealer or have an independent mechanic replace the hosing. Since I’m not replacing with Lexus OEM parts, (duhh) if it must go to the dealer I’ll end up take it to the Toyota dealership that services my Land Cruiser.
Any suggestions would be greatly appreciated.
Old May 1, 2012 | 04:37 AM
Ancient's Avatar
Ancient
I guess no one wants to remove there engine covers to see how they are routed and answer that question. I am assuming that the hoses were eaten in the engine compartment, since that is the most accessible. Vacuum or washer fluid hoses are probably the easiest to fix. However, front to back line is not going to be cheap. Since this runs inside the car, you may not have to replace this line.
Ford had a commercial about using soy based foam in their car seats. Won't be long before we see mice getting inside cars, when the window is left down a 1/2 inch. Not everything that is green for the environment is good. Good luck.
Old May 1, 2012 | 09:22 AM
RCsGX's Avatar
RCsGX
Removing the engine covers wont show you anything. Mine are removed and you cant see how the hose comes off of the windshield fluid reservoir. If you open the hood you can obviously see the hose that leads up to the nozzles on the hood but its routed though the fender so you cant even see how thats routed.
amilleroh
Dec 1, 2013 10:43 AM
xtremex626
Aug 8, 2011 10:03 AM
denverdog
Apr 4, 2007 10:48 AM
