Driver's master window control
Old Jan 17, 2012 | 05:16 AM
ronmay's Avatar
ronmay
Default Driver's master window control
Hello all. I am a newbie Gx470 owner. Please excuse me if this has been covered before. I just finished a timing belt job on my 2005 Gx470 with 127K on the clock. After the work, the driver's
master window control would not activate any window but the drivers. On a recent outing my wife activated the passenger' window. I suddenly regained control of that window from the drivers position. You guessed it, when I ran the rear windows up and down, I regained control of them also. Hope this saves someone some time and trouble.
Old Jan 17, 2012 | 09:12 AM
ALAN553's Avatar
ALAN553
Once you disconnect the battery, auto up/down feature from drivers panel needs to be reset.
Old Sep 3, 2012 | 07:20 AM
TKukes's Avatar
TKukes
I removed the passenger door panel to replace a speaker on my 2004 GX470. Everything went well and got put back together just fine. I checked the window and the lock before putting it all back and they worked fine. However, when I was all done and had to go someplace later, I could not roll the window down from the drivers side controller. Controllers on passenger side work fine still.
How do you 'reset'?
Old Sep 4, 2012 | 12:31 AM
mann777's Avatar
mann777
Here is the method.. Hope this helps
cooperww
Nov 10, 2018 08:16 AM
prex
Jan 24, 2016 10:13 PM
edgy
RX - 1st Gen (1999-2003)
15
Dec 29, 2015 08:11 PM
sneakyazn
May 1, 2008 02:14 PM
tjschnei
Apr 28, 2007 03:01 PM
