Radiator Replaced
Old Nov 22, 2010 | 07:56 AM
LVLEXUS's Avatar
LVLEXUS
Default Radiator Replaced
At 74K miles..radiator started to leak...guess there are two plastic tanks, one on each side of radiator. Tank was leaking on driver side. From what I have read here, 04's had a design issue, based on recommendations of members here on CL...went with a high end KoyoRad....parts and installation total cost $400. Including Lexus coolant!
Read this....
Dear XXXXXXXXXX,
When you recently brought your 2004 Lexus GX 470 in for service at Lexus of XXXXX, we performed a World Class Inspection. There were recommendations from that inspection which may be significant to the ongoing performance and safety of your vehicle. Please refer to the details below for more information.
I will be calling you in the next few days to discuss these important services with you. In the meanwhile, please call me at your convenience at (XXX) XXX-XXXX if you have any questions. When you are ready to have this work taken care of, you can either contact me directly, or call our service department at the number below, to arrange a time that works best for you.
In appreciation for your business, we are pleased to offer you a limited-time coupon which you can redeem when you bring your vehicle in to perform these recommended services. In order to view and print your coupon, please click on the Recommended Service Coupon link below.
Regards,
TO SEE YOUR SAVINGS CLICK THIS LINK: Recommended Service Coupon
RECOMMENDED SERVICES FOR YOUR 2004 Lexus GX 470
FROM RECENT VISIT - VIN#XXXXXXX
Task / Observations Recommendation Status Estimate Additional Info
Task: Check engine coolant level and condition and check for leaks
Observations: Found coolant leak Replace radiator Fail $1,430.00
ESTIMATED TOTAL $1,430.00
HAVING DIFFICULTY VIEWING THESE SERVICE DETAILS? PLEASE CLICK ON THIS LINK: Recommendation Details
FOOTNOTE 1 | Radiator replacement
Operation Description:
A trained automotive technician will disassemble the components surrounding the engine radiator including the cooling fan(s), air conditioning condenser, sensors, hoses and bracket. The technician will then drain the radiator coolant and ensure it is properly recycled. The technician then carefully removes the radiator hoses from the radiator housing. The new radiator is carefully installed, the components are re-assembled and the hoses are connected. The technician fills the radiator and cooling system with the factory-recommended coolant mixture. A test is then conducted to ensure proper engine cooling and system soundness.
Significance:
The radiator is an integral component of the cooling system. Engine coolant leaks from your vehicle’s radiator indicate age and reduced efficiency of the radiator. A leaking raditaor is like a ticking time bomb. It's not a matter of if it fails, but when. If a leaking radiator bursts while you are driving, the engine can lose all of its coolant and overheat. The result can be expensive engine damage.
Advantage:
By properly maintaining your vehicle's cooling system, of which the radiator is a major component, you will make sure that the engine is properly cooled. This benefits you because your engine will run efficiently and “healthy”, and the other cooling system components will work better and longer. Replacing the radiator when a leak is first discovered can also save you money by avoiding possible engine damage and costly engine repairs.
Leaking radiator
New radiator
Old Nov 22, 2010 | 08:40 AM
mann777's Avatar
mann777
In short they are "Stealerships"
Old Aug 5, 2012 | 11:45 AM
isaias's Avatar
isaias
That's great you posted their letter so they know how "carefully" ridiculous they sound "carefully removing" all that money from hard working individuals.
Old Aug 5, 2012 | 02:58 PM
sprocket's Avatar
sprocket
Where did you have it installed? Toyota or local shop?
TDC1
GX - 1st Gen (2003-2009)
19
Nov 12, 2018 10:56 AM
vipergts
Hybrid Technology
Nov 21, 2015 10:04 AM
LEXTECH
Oct 17, 2014 06:07 PM
XxSC400xX
Feb 3, 2012 12:22 PM
dealerdeb
15
Jan 8, 2011 06:04 PM
