Removing rear bumper cover
Old Dec 2, 2009 | 10:31 AM
rrolff's Avatar
rrolff
Default Removing rear bumper cover
Haven't seen anything on this here - has anyone actually removed the cover? I've got a primered one that I'm swapping in...
TIA
Old Dec 3, 2009 | 10:55 AM
mann777's Avatar
mann777
To remove the rear bumper, you should start to remove the components which are on the frame, once u open the door. All the links, need to be disengaged from its claws and then remove the hole cover. Always make sure you tape the screw driver tip with tape, so that they done scratch around. Remove all the bolts and the back door stays. You could remove all the bolts in a sequence from the left to the right , then the whole bumper could be removed. There are total 7 bolts, 4 screws and clips in all. So get going !! One thing I missed, ensure if you have the towing hitch installed remvoe that first in sequence, then you move to rear wheel well area from teh left and remove all the reinenfrorcements in sequence.
Old Dec 4, 2009 | 02:19 PM
mann777's Avatar
mann777
Here is the link to the parts which are holding to the framehttp://www.sewellpartsonline.com/***...l=205&year=165
msekanha
Oct 29, 2020 12:48 PM
Schimmy
Feb 11, 2019 06:57 PM
KOKISF
IS F (2008-2014)
Oct 4, 2014 12:55 PM
aron7awol
Jun 8, 2009 10:17 AM
ttran076
Aug 26, 2007 11:05 AM
