Remote start
I would be concerned (or at the least, curious) about the range of the LuxLink. If it's using the existing remote, you're not going to be able to start your GX very far away.
Here's another vote for the Viper 791. About $700 professionally installed with alarm and remote 2-way starter (the LED remote shows that the car is actually running, plus shows if there's a break-in). Farthest I've been able to start it is a little over 1/4 mile. Starts easily through 5 walls in my home.
Another thing to consider is the battery life of the LuxLink. Since you'll be using your remote 3 times more often (press 3 times to start), that will probably significantly shorten battery life. Vipers take 2 AAA's and are exchangable in about 1 minute.
Dr. EinTN,
You're pricing is about right. I believe the extra remote is $150 +/- and if you add extra door and hood triggers, etc. the prices tops $1,000.00.
Still worth the price IMHO. Other systems can be done for much less money (one could DIY the Viper for under $500, if they are an electronics wiz!), but this is still the best money can buy, much like our Lexus'.
Dr. EinTN,
My wife and I just bought an 05' GX. I made an appointment to take our old ES into an automotive shop Wed. and swap out the old remote into our GX. They told me on our 05' that they will have to add a module ( but i cannot remember want they called it). Cannot recall the name brand of the remote start, but i know it has a two way control pod to let you know that the truck is running, inside temp, doors locked/unlocked, etc...
The valet key that was mentioned. Is that the credit card looking key the dealer gave me, or is there another key?
If you didn't get a valet key, you might want to ask the dealer...
ok... so based upon the replies.... Luxlink is the only remote start that utilizes the original key fob. Is this true? I want to get a remote starter... however, not interested in an additional remote...
How much is the Luxlink? The website doesn't list price. Can you get a Lexus dealer to install?
Any other suggestions?
STL2CHI
STL2CHI
STL2CHI
STL2CHI
They need to cannibalize something to get the transmitter with the code that allows you to start your engine. The valet key looks just like the regular key, but doesn't have the remote buttons on it. You should have been given one of these along with two regular keys. The credit card key is flat and is for emergencies (you have to hold one of the pieces near the starter to use it). I assume you can use this, but not sure if it has limited uses or something - best to check.
Well, i picked up the GX earlier. I'm very happy with it. Not too sure what they needed the key card for, i found it on the floor. It might have slid down from somewhere, either way, the plastic was never broke open. Truck starts like normal, the OEM keys still work. The only way i can tell any difference is when I remote start the truck, there will be a red flashing car symbol with the outline of a key going on and off in the center of the control panel. Until I insert the key and turn the ignition, then it goes away. I assume this is normal. Other wise there are no Ill affects to the truck.
Sounds like they use the credit card key chip for the immoblizer bypass module. You might want to try out the credit card key so you wont getting surprise when you need to use it, they might have took the chip out of it. BTW, how much was the total install?
I asked them today if they had to use the chip for anything, since the package wasn't opened. They told me no, that there was a new modual available for my model and they went ahead and tried that. Everything worked out fine with it.
I swapped it out from our old Lexus. So uninstall was 40. reinstall is around 130+/- a couple dollars. Then a new wire harness was 15., and the modual was around 30 i think. came to about 230.
The starter itself has a 2-way transmitter, that lets you know your vehicle is started, among other things.
Nope, it has its own transmitter. The OEM key remotes still work, which is cool, and i still use. But, the transmitter actually lets me know if the vehical started or not. I can start this thing from inside a steel mill while the mill is arching down, and i'm a good 1000ft away inside a little building where i cannot see the truck.
