Using Camera w/o reverse... here is the Diag screen shortcut
Old Jan 24, 2006 | 09:58 PM
lex430's Avatar
lex430
Originally Posted by Capirato
Hi Tony...
I experimented with the Back-Up Camera override code last night.
If you can do the Nav override code, this is very much the same. You press the Display button, then you do the upper left, lower left, three times. You will get a new screen. Then touch Menu on the screen, you will get another screen. Touch the bottom choice on the menu. That will turn on the Camera.
~ Cap
I am so excited when I found this only thread that discussed how to manually activate the backup camera. Then I realized I did not have a 'Display' button.
I have an 04' LS with UL, anyone know what the sequence should be?
Old Jan 24, 2006 | 10:04 PM
robinzon's Avatar
robinzon
lex430,
Problem easily solved... hold down the INFO button then Turn your parking lights (ie or lights in general) on and off 3 times while holding the info button... this will get you to same menu (or at least I hope so on the LS)
thanks
This only works on 04 trucks and older... 05 and 06 just get a GREY screen...
Old Jan 24, 2006 | 10:16 PM
lex430's Avatar
lex430
Originally Posted by robinzon
lex430,
thanks
I got the diagnostic menu, but similar to a post above. I see a button with "Camera Check", and when pressed, it takes me to a grey screen with version number and another button that says "ok". No image.
Old Jan 28, 2006 | 10:15 AM
lepoch's Avatar
lepoch
Hit DISPLAY then hit the screen LEFT UPPER/LEFT LOWER x 3
On a 2005 GX with the V5 disk this doesn't work, but the trick of holding INFO and turning the lights on and off does.
Old Jan 28, 2006 | 10:40 AM
ELEX470's Avatar
ELEX470
Angry nop not working on 2005
that also is not working on 2005
Old Feb 1, 2006 | 05:34 AM
jdh62's Avatar
jdh62
I could not get the first method (Display and then touch upper left and lower left three times) to work, as everytime I touched the lower left hand corner, I kept adjusting the contrast. However, robinzn's method for LS (hold Info button and turn on/off lights 3 times) worked beautifully on 2004 GX-470! Thanks!
Old Feb 1, 2006 | 05:47 AM
Capirato's Avatar
Capirato
The first method works fine with my 2004 GX470.
You have to stay within the center section of the screen, not all the way to the corners
~ Cap
Old Feb 3, 2006 | 12:23 PM
Joel888's Avatar
Joel888
Question
Guys,
Any of these methods would work on 05 GX?
Old Jul 27, 2006 | 01:22 PM
Lou19's Avatar
Lou19
My '06 gives me the gray test screen also. Is there a wire we can apply power to, with a bypass switch, that will display the rear camera anytime?
Old Jul 28, 2006 | 05:40 AM
4everlexus's Avatar
4everlexus
Default Back Up Camera Overide
Hi All:
I have been trolling this thread (and others) for a very long time about the above referenced topic and find that my 2005 GX does not allow for the backup camera to be activated while driving and I have tried EVERY know Easter Egg mentioned! If anyone knows of one that will work, I (along with others) would appreciate a post.
Thank you!
Old Jul 31, 2006 | 09:09 AM
CVsIS250's Avatar
CVsIS250
It doesn't work in my 06 either...Toyota caught on and disabled this easter egg on the 05.
CV
Old Nov 13, 2006 | 03:34 PM
maniaclx47's Avatar
maniaclx47
Originally Posted by 4everlexus
Hi All:
Thank you!
to turn on the camera
try this.
after you get the screen with camera check, tap the camera check.
you should get a grayed/greened screen with some warnings at the bottom.
from that screen, do the following...
tap
top middle
bottom middle
top middle
bottom middle
top middle
bottom middle
top middle
bottom middle
top middle
bottom middle
and the camera will turn on.
do it with the engine running.
Old Nov 21, 2006 | 09:26 PM
lex430's Avatar
lex430
Thanks maniaclx47!!! This works on my 04 LS. I just couldn't get out of the diagnostic menu w/out shutting the car down and turn it back on.
Is there anyway to get out of the diag screen w/out turning the car off? A previous post stated to hold down the "Display" button for few seconds, but there is no such button in the LS.
Any other suggestion?
try this.
tap
top middle
bottom middle
top middle
bottom middle
top middle
bottom middle
top middle
bottom middle
top middle
bottom middle
vew702
ES - 7th Gen (2019-2025)
Mar 17, 2019 08:27 AM
Brillo258
14
Aug 27, 2013 11:17 PM
LuckyGX
GX - 1st Gen (2003-2009)
Jan 28, 2007 04:16 PM
Kavistar
May 24, 2006 10:15 AM
CVsIS250
May 8, 2006 06:49 AM
