Bluetooth Question
Old Apr 21, 2005 | 07:42 AM
Gohawks63's Avatar
Gohawks63
Default Bluetooth Question
I also posted this on the LX board since I know the system in my LC is the same as that. I know I own a Land Cruiser, but I'm hoping the systems are similar.
Is there a way to "quickly" bypass the Bluetooth handsfree option for a particular call?
I have the Motorola V551. I successfully made the connections, and downloaded the address books to the Land Cruiser from both my phone and my wife's. The system seems to work flawlessly.
I just want to know if I can quickly transition to a handset, let's say for privacy if I have someone else in the car or if it get's too noisy.
I know I can turn off Bluetooth on the phone, but while on a call it would take a couple of steps.
I did look through the setup menus on the truck and nothing stands out. I'm going to comb through the trucks owner's manual again to see if I missed something.
THoughts?
Old Apr 21, 2005 | 08:39 AM
lonewolf69's Avatar
lonewolf69
Have been using bluetooth for at least two years before I had my GX, same problem with the BLUETOOTH headset (Phone and Headset matching Sony Ericsson) and unfortunately the answer is no...
Maybe the Motorola is different but I doubt it, as by default BLUETOOTH protocol is set for "active" scanning for incoming signel...
I usually just ask the caller to call back later... or I hang up and redial with bluetooth off, ambient noise (kids, traffic, "spouse" , other instances) will affect BLUETOOTH operation...
Old Apr 21, 2005 | 11:00 AM
Gohawks63's Avatar
Gohawks63
I think I figured out a work around. I just set up a shortcut to turn on/off the Bluetooth feature on my phone.
"Menu"+"2" = On
"Menu"+"3" = Off
So while I'm on the call and if I hit Menu 3, it should terminate the connection and ask me if I want to continue the call. I'll try it out and let you know.
Old Apr 21, 2005 | 12:39 PM
bunka's Avatar
bunka
THoughts?
I actually have a MUCH faster method for you. I don't know if this works on the Lexus system (my GX is an 04 without BT) but on my Acura TL all I have to do is push the voice recognition button and say "transfer". The Acura NAVI/Handsfree then shuts down the BT session to the phone and I can then continue to talk/listen "privately" on the phone itself. At that point, you cannot use any of the handsfree headsets as the transfer function essentially is transferring off the bluetooth ports but it works great for privacy. It does take about 5 seconds to complete the transfer though. Maybe you could try this on your system and let us know if it works.
Old Apr 22, 2005 | 03:51 AM
Gohawks63's Avatar
Gohawks63
"Menu"+"2" = On
"Menu"+"3" = Off
FYI. This method works perfectly.
pjarvis
GX - 1st Gen (2003-2009)
Apr 4, 2009 08:26 AM
david blac
Mar 4, 2006 08:51 AM
silverado
Jan 13, 2006 09:12 PM
Bronsteen
Dec 14, 2004 06:50 PM
