Bluetooth question
Old Jan 29, 2025 | 03:56 PM
richedmo's Avatar
richedmo
1st Gear
Default Bluetooth question
My 2006 GX470 emits a tone about one minute after starting the car. At the same time the radio/nav screen displays the message "Bluetooth connection failed". I know the vehicle did not come with BT and that someone must have added a device that the radio/nav system works with in order to show the message. I've held various BT devices near the the dash and none have connected, so I'm not sure what is going on. The disc unit in the glovebox is intact. Any thoughts on if there is a BT unit in the vehicle or not and if so, any ideas on 1)how to get it to work or 2)how to turn off the tone and message. Thanks
Old Jan 29, 2025 | 05:46 PM
ALAN553's Avatar
ALAN553
they did have BT, not sure what year it started….it just doesn’t connect, you have to go to the pairing setting on the nav screen and then on the phone. If the screen says failed to connect…guess what? It has BT.
Old Jan 30, 2025 | 12:14 PM
mcomer's Avatar
mcomer
2006 GX 470 did offer BlueTooth, Here is a screen shot of Owner's Manual page 110 with a picture of the steering wheel. If you have those buttons, it has BT.
Old Jan 30, 2025 | 01:33 PM
chiph9's Avatar
chiph9
If your GX doesn't have the BT buttons on the wheel, the previous owner might have installed an aftermarket BT unit, then removed it prior to sale.
Chip H.
Old Jan 30, 2025 | 07:25 PM
TheLilJohn's Avatar
TheLilJohn
If you have the Nav head unit, you should have BT. My 2005 did and went through the same issue you note: 1 minute then beeping about BT connection failure.
I want to say I had to go through the 'phone' section of the nav interface. I'll see if I can find specific instructions if you can't find them online.
benwah
Nov 8, 2022 02:58 PM
itsZep
GX - 1st Gen (2003-2009)
Feb 20, 2009 10:46 AM
Jayson
12
Sep 27, 2006 02:26 PM
julieh
36
Feb 1, 2006 07:42 PM
