Brakes lock up on panic stop
Subscribe
Nov 20, 2024 | 11:12 AM
Quote: They are a bit larger. I hadn't considered the load rating and that affecting the lockup nor the fact that they were AT's. I know there is a lot of discussion on the forum about tires but is there a tire you run you are happy with?
The larger circumference will change the gearing (slower acceleration, speedometer error), and increased weight (rotational weight is far more noticeable than static weight), but should not contribute to locking up when braking.
I've been running C-load rating 265/70/17's on my GX470 for years, this is the 2nd set, no ill effects to note.
Reply 0
Nov 21, 2024 | 02:42 AM
Sounds good, I will get the correct load rating next time I'm due for tires in spring. Thanks again for your help!
Reply 0
Subscribe
