Aftermarket Solution for Power Window Assembly
My wife's 2007 GX470 was having battery drain issues. I tracked it to the little lights on the power window switch never turning off. I pulled it, and it looked like an aftermarket unit. I bought another aftermarket unit and sure enough, I had the same problem. Has anyone had any luck with replacing these with something. Non-OEM? I'm not paying almost $700 for that part from Lexus.
What part number have you been using? Amayama shows four different numbers:
84040-60070 discontinued
84040-60071 in stock for $210
84040-60072 out of stock
84040-60073 discontinued
https://www.amayama.com/en/catalogs/...y-computer-337 (scroll all the way down)
Note that this is just the switches - the bezel is a different part and needs to be matched to your interior color.
Chip H.
Chip H.
84040-60073 was the part I was specifically looking for based on what I found on LexusPartsNow.com. Any idea what the interchangeability of parts is? $210 isn't the worst. Way better than the Lexus website, but LexusPartsNow.com says that it isn't compatible.
mk4r34
Feb 19, 2013 06:51 PM
