Brake Recommendations
Old Aug 5, 2023 | 06:31 AM
  #31
ALAN553's Avatar
ALAN553
Originally Posted by muldowney2
did the upgrade to the 460 pads, rotors, and calipers -
drives like a dream
also added SS brake lines, front and back…now it rides and stops like a Lexus.
Old Nov 3, 2023 | 01:52 PM
  #32
mtbphxnomad's Avatar
mtbphxnomad
I'm looking at getting a stainless steel brake line set. I spent a few minutes looking at the rears under the GX and didn't really notice any banjo fittings but in the stainless steel kits of 6 lines, 2 front, 4 back, it appears two of the brake lines have banjo fittings. Am I looking at the right set of lines?
Are there good options for the set of brake lines aside from this set?
https://www.summitracing.com/parts/p...33?seid=srese1
Old Nov 4, 2023 | 05:30 AM
  #33
ALAN553's Avatar
ALAN553
i used stop tech lines, two front, two rear
Old Nov 4, 2023 | 08:24 AM
  #34
chiph9's Avatar
chiph9
@ALAN553 - there are two additional flexible lines in the rear to carry fluid from the frame to the axle.
Chip H.
Old Nov 4, 2023 | 10:18 AM
  #35
ALAN553's Avatar
ALAN553
Yea…that may be, but only changed 2 front, 2 back and 460 calipers and rotors up front…stops like a Lexus now.
Old Nov 4, 2023 | 11:58 AM
  #36
mtbphxnomad
Chip H.
@chiph9 or anyone. Do you know of a kit online which contains all 6 lines?
Old Nov 7, 2023 | 06:00 AM
  #37
NTH's Avatar
NTH
Looks like you’ve already found a kit with 6 lines, no?
Old Nov 7, 2023 | 08:24 AM
  #38
mtbphxnomad
I sorted it out yes! thx
Old Nov 7, 2023 | 02:12 PM
  #39
NTH's Avatar
NTH
Thats the right set. The two lines with banjo fittings are for your rear calipers. Crawl under yours and look again.
Old May 22, 2024 | 08:05 AM
  #40
Matsui's Avatar
Matsui
Its time for me to get the front and rear brakes and rotors replaced, so I'm planning to upgrade to the GX460 setup and go with the Power Stop Z36 kit mentioned above and the flexible lines. Hope those who went with Power Stop upgrade are still happy with the results as I don't want to spend so much on the OEM because of the cost. This thread already has really good info, but please feel free to share any tips or advice if you have any based on your experience. Will start looking around to find a seller because I think RockAuto is out of it right now.
I also need to replace CV axles and inner/outer tie rods so will search the threads on that topic as well.
Old May 25, 2024 | 04:34 AM
  #41
Matsui's Avatar
Matsui
My mechanic thinks that the 2010 calipers may not fit and rub since I have bigger tires (285/70/17). Does anyone have experience using this kit with bigger tires?
Old May 25, 2024 | 02:47 PM
  #42
ALAN553's Avatar
ALAN553
First…isn’t it about the wheel size fitting around calipers? The stock wheel fit
Old May 26, 2024 | 07:33 AM
  #43
Matsui's Avatar
Matsui
I got the Method 17" wheels with 0 offset an 4.75 backing. Since they stick out more than stocks, I assume the calipers should fit?
Old May 26, 2024 | 11:22 AM
  #44
ALAN553's Avatar
ALAN553
Fit was not an issue with OEM 17" wheels, can't speak to your aftermarket wheels
Old May 27, 2024 | 06:06 AM
  #45
NTH's Avatar
NTH
No disrespect to your mechanic but if he thinks bigger calipers may not fit with bigger tires, you need to find a new mechanic.
With regards to brakes, I’m very pleased with the Z 36 package. I have used these brakes, rotors and pads, on both my GX, and they have performed flawlessly. More braking power than stock for sure.
