Removing rear seat, sunshade problem
Old Nov 19, 2013 | 05:38 AM
tbilisi79's Avatar
tbilisi79
Default Removing rear seat, sunshade problem
Hey guys. My rear sunshade got stuck half way. I can raise it manually and the motor works.
How do I remove the back seat to access the sun shade mechanism?
Old Nov 19, 2013 | 09:19 AM
XxGoKoUxX's Avatar
XxGoKoUxX
Tbilis, there's an old thread somewhere about someone showing a step-by-step on hwo to remove the rear seats.... it's driving me nuts that I can't find it!
Old Nov 19, 2013 | 10:55 AM
alchemist's Avatar
alchemist
could possibly be same as the IS?
1. pop the seat cushion by pulling the seat upwards. the cushion should pop off easily. push the seatbelt buckles through the slots. the cushion now can be removed completely.
2. At the bottom end of the seatback, there are 4 black 12mm bolts that secure the seatback. one of each near the door and two of them are near the center console. DO NOT remove the seatbelt anchor bolts which are 14 mm. lift the seatback to free it from the three upper clips.
3. remove the C pillar cover. start from the lower edge and just using fingers to carefully pry them off. each piece should be held down by three blue plastic clips.
4. pop off the rear deck by lifting the front edge carefully. it's held down by three clips.
5. you now have access to the subwoofer or the brake light. the subwoofer is secured by four 10 mm bolts.
Old Nov 19, 2013 | 02:57 PM
tbilisi79's Avatar
tbilisi79
Thanks. I found all the diagrams and write ups .
For now I just raises the shade and pulled the fuse.
Will rip the whole thing out and try to fix it at some point .
Old Nov 19, 2013 | 03:24 PM
ISFjimmy's Avatar
ISFjimmy
Think you can post up the diagram just in case mine ever goes out of alignment?
Old Nov 20, 2013 | 02:42 AM
IXI187IXI's Avatar
IXI187IXI
if you need help with that, check the pdf
File Type: pdf
Zeke21
Jun 14, 2022 12:32 PM
MicaISF
IS F (2008-2014)
14
Apr 3, 2015 09:34 PM
ihiryu
IS F (2008-2014)
Nov 3, 2014 10:28 AM
Poisson
Nov 14, 2011 05:59 AM
mad_trbo
GS - 1st Gen (1993-1997)
Nov 26, 2008 04:56 AM
