VSC ON/ VSC OFF problem SOLVED!
Keep in mind caps are band-aids and though it can help the amplifier get the surge power it needs it's still just another device adding load to your stock battery and alternator. If you are really dropping that much voltage from a large stereo the best thing you can do is add a second battery and charging isolator just for the stereo. The isolator will still allow the alternator to charge the second battery but completely keeps the amps and second battery from interfering with the rest of the cars electrical system. And if you play the stereo with the engine off til the second battery dies the car battery will still be charged and you won't be stuck.
I wish Lexus used a better way to give us a low voltage indication.
I use a onboard voltmeter to monitor alternator output via Scangauge.
I have noticed that when my alternator was going out, no output at idle, there were no dash lights given, even though my voltmeter read under 12 volts with the motor on.
Here's my situation.
98 GS4 184k. No suspension work in last 12 months. Stock suspension. No leaking fluids
2 months ago car wouldn't start one morning. Jumped it and took it to have the battery tested. Tested good but needing charge. Charged battery and all was good.
3 weeks ago same issue. Cleaned terminals, added distilled water to battery and put on charger. Wouldn't take a full charge so installed a new battery.
Yesterday morning started the car and got a loud humming noise from engine. Humming speeds up with RPM but gets quieter after motor runs a while. (Traced the humming to the area around the P/S pump and/or alternator.)
Yesterday afternoon on my way home the VSC, ABS and VSC OFF lights come on. Car seemed to run fine. Got home, shut off car and re-started. No VSC, ABS or VSC OFF lights come on. All is fine except for the humming noise is back this morning.
I guess the next step would e to have the alternator tested.
Any other ideas?
TIA,
JimA
A multimeter is used to measure voltage (ac or dc), resistance (in ohms), and other features depending on capabilities.
The basic digital multimeter will perform many functions as well as the best tools in your tool box for electrical testing anywhere.
BTW - good for you for sticking with it to find the problem. Troubleshooting can be a PITB, but it takes discipline.
Big Mack
Any other ideas?
TIA,
JimA
