Extra UCA clearance
Old Apr 26, 2009 | 09:46 AM
taeng's Avatar
taeng
Default Extra UCA clearance
If you're lowered enough you know your UCA's are slamming into your chasis and causing you to cringe every time. I meet a fabricator who confidently said he can do the box out and weld it up with ease. Being that he was so confident I instantly agreed to let him do the work. It's not that difficult to do, but finding someone who understands what needs to be done and willingness to do it is difficult to find. I couldn't be more happy with the end result.
Old Apr 26, 2009 | 09:51 AM
chrispy's Avatar
chrispy
Looks completely OEM. That is some fine craftsmanship.
Old Apr 26, 2009 | 10:01 AM
taeng's Avatar
taeng
Thanks Chris, that was exactly what I was looking for. I was thinking about doing the hole saw route, but I didn't want to see a hole every time I popped the hood.
Old Apr 26, 2009 | 10:03 AM
krappy's Avatar
krappy
what did it end up costing you?
Old Apr 26, 2009 | 10:08 AM
chrispy's Avatar
chrispy
I'm thinking about cutting some clean holes in my engine bay and chroming or polishing my UCAs because they will peek through the holes when I dump the car all the way down.
Old Apr 26, 2009 | 10:20 AM
taeng's Avatar
taeng
That sounds like a cool idea, kinda bare bones show off like a ruckus LOL
Old Apr 26, 2009 | 11:05 AM
kit cat's Avatar
kit cat
niiice! i need to contact my welder for this too.
thanks for posting them up!!!
Old Apr 26, 2009 | 11:23 AM
sleeper408's Avatar
sleeper408
That would be pretty creative.
Taeng: That looks very clean and well-done. Problem solved! No more loud bangs over huge bumps and dips right?
Old Apr 26, 2009 | 08:11 PM
tom steele's Avatar
tom steele
thanks i have been wanting to cut my front so when i air out it will go lower in the front but i don't think my problem is the upper control arm hits what size rims are you running because my tires rub before my control arms hit i do have 20s though ill have to take a closer look i am going to take the fenders off and see what i can do to get more clearance also install bump stops right before bottom out sucks to be stuck on the side of the road made a u turn and rubbed thru my air line forgot to re zip tie it when i did my brake upgrade also are you guys on bags or coil overs.i'll try to post pics when i do this it is sure nice to have welders and a plasma cutter in my garage !!!!!
Old Apr 26, 2009 | 08:26 PM
denut-L's Avatar
denut-L
Sweet, i would also like to know how much something like this would cost and how long did it take?
Old Apr 26, 2009 | 08:42 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
He was also running 20s Maya RT5s.
Old Apr 26, 2009 | 09:28 PM
taeng's Avatar
taeng
As for right now my UCA's haven't made contact. I'm also a 1/2 higher (still winter mode) then my normal height. Once my rims come in I'll bring it back down and see how it goes. I could tell you that I know it will help alot on dips and bumps, but if it's a big enough dip or bump I'm sure it will still make contact.
I had 20's before, running stock 17's now and will be running 19's soon. I'm on coils
It costed a a pretty penny a little over $500, but I think it's well worth it. I won't have to cringe anymore or at least not as much and it looks OEM.
Old Apr 27, 2009 | 08:16 AM
Rich27's Avatar
Rich27
Thanks for posting the pictures! The work looks amazing!
Old Apr 27, 2009 | 08:21 AM
GS300ToM's Avatar
GS300ToM
very clean in deed... looks great
Old Apr 27, 2009 | 09:12 AM
V8RdnLow's Avatar
V8RdnLow
That looks really good! I wonder if I can find someone here in cali to do that for me......
