Car wash = wet floor board.
Old Dec 7, 2007 | 09:17 AM
YeShrug's Avatar
YeShrug
Default Car wash = wet floor board.
noticed some soap suds on my passenger side rubber floor mat, and some water on the channels(meant for trapping fluid/mud etc).
I have a little water that got the carpet, and when I opened the glove box, the cabin filter was soaked too.
Short of pouring more water on the windshield, what should I do to try and seal the leak.
Anyone had this happen(search turns up a lot of a/c related issues), and*thankfully* this isnt coolant leaking.
Old Dec 7, 2007 | 01:20 PM
David1969's Avatar
David1969
Hasn't happened to me so don't know what to tell you. Sounds like some piece of rubber or something used to deflect the water away has deteriorated or has fallen off. Shouldn't be that hard to find. Post up when you figure it out and fix it.
OT: Where did you mount the Zapco? I've got 2 that are in my closet waiting for install some time this decade.
Old Dec 7, 2007 | 01:50 PM
TruPlaya26's Avatar
TruPlaya26
CL Folding 10,000
If you can't figure it out soon take it to the dealership and see if they can find the leak, you don't want water getting in your car everytime it rains ...
OT as well: sorry if i sound stupid but what is zapco? never heard of it
Old Dec 7, 2007 | 03:46 PM
chinkster's Avatar
chinkster
if you've had your windshield replaced before, make sure the seal on the windshield is good. that was the problem i had on my civic. took it to a cheap windshield replacement spot... cheap windshield but their labor to install it was ****ty as hell
Old Dec 7, 2007 | 06:05 PM
Lexamatic's Avatar
Lexamatic
Check the conditon of the window/door seals as well as the seals on the sunroof. Lexus (Toyota) rubber seals are top quality but will deteriorate over time.
A poor quality windshield replacement is also one of the usual suspects.
Old Dec 7, 2007 | 06:44 PM
DangGS3's Avatar
DangGS3
same exact thing happen to my bimmer. searched everywhere to see where that darn leak came from. i think its the window seal too
Old Dec 7, 2007 | 08:07 PM
bigguppy's Avatar
bigguppy
Sounds like your windshild. Try useing a air gun or a hair blow dryer and have someone blow agaist the winshild to find where the may be. And also concider checking the drain system where the windshild blade sits on. You may have a crack
random pix, thought it may give u an idea.
Old Dec 7, 2007 | 08:27 PM
UncleRay's Avatar
UncleRay
Open your hood and check your firewall. It's the rubber piece that connects the wiring from under the hood, to your dash area. It might be damaged. If it is, take some sealant, and seal that puppy =]
Old Dec 7, 2007 | 09:48 PM
Dslexic's Avatar
Dslexic
CL Folding 10,000
Have 2 people check it, one outside spraying water gradually, another inside to check for water?
Old Dec 8, 2007 | 10:42 AM
99Aristo's Avatar
99Aristo
Another thought especially since it wa sin your cabin filter would be that it got into your fresh air vent bat the hood cowl area and ran into the hvac housing and onto the floor. This would explain why it wa son your florr and the cabin filter. but it is possible that the windshield is F%*ked up also, only problem with that is if it was the windshield you'd more than likely here a windnoise. Part of my job at work is dealing with stuff like this so I'm kinda used to it.
Old Jan 26, 2008 | 11:07 AM
YeShrug's Avatar
YeShrug
sorry about the delayed response. Picked up a mustang that has me on ford forums all day lol.
top left..it was perfect, this box was built specifically for my 02 TL-S, and it fit PERFECT in my trunk, with just enough clearance for the amp and some breathing room.
kellydon09
RX - 1st Gen (1999-2003)
Dec 25, 2019 10:59 PM
User 11220
Oct 11, 2019 06:46 AM
jdanh
Mar 4, 2008 04:26 PM
chrisleX
May 28, 2004 06:25 PM
