wheel spacers
spacer and spring will break the balance of suspension geometry and change the rolling center point of the car. Lower you car doesn't give you better handling, it only changes the subjective driving feed back. 99% of suspension mods will make the handling worse. spacer change the center point of tire and wheel center, be careful with anything change your suspension geometry. I am strongly recommend not to lower your car.
Stormryu (02-21-17)
Contact us please!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Coming from a guy that's modding his car heavily adding a supercharger on a stock block most likely isn't smart either but you don't recommend lowering a car please send me a link that states lowering a car is going to make it worse. I can see if you have a crazy amount of negative camber but who's going to slam a GSF that much? Yes I can see wheel spacer isn't the best option.
http://www.americanmuscle.com/suspen...ide-part3.html
this is link
http://www.motoiq.com/MagazineArticl...-Your-Car.aspx
I mean you will compromise your traction performance in corner anyway you mod your suspension, if you really want to do it, use a coliover and find a decent shop to correct your suspension geometry
Tech Info Resource
I decided not to put the supercharger kit on my car, I don't want to take that risk.
this is link
this is link
13FSPORT (02-22-17)
Tech Info Resource
RTIS250
CT 200h Model (2011-2017)
33
12-07-15 10:00 PM
