Square setup?
Old 05-03-17, 06:09 PM
saifm73
saifm73's Avatar
Default Square setup?
I was wondering if you can get a square setup on 265/35-19 which are the size of the rear tires all around on stock wheels?
Old 05-04-17, 07:18 AM
sarmyth
sarmyth's Avatar
Talking
I'd be surprised if you could but I initially had the same desire that you do. 255 is what you're looking at if you buy new rims and carefully match your offsets in the front. The GS-F's front's are also 255.
I run 245/275 w/RR Racing's lower control arm bushing and couldn't be happier. Changing the sloppy OEM bushing is the key to eliminating understeer in the front if that's what you're after with a square setup.
If you're just after being able to rotate your tires, downgrade to 245's all around
Old 05-04-17, 10:56 AM
saifm73
saifm73's Avatar
So if i just want to rotate my tires all i have to do is downgrade to 245's all around so 245-40-19 and 245-35-19 or all four 245-35-19?
Old 05-04-17, 01:06 PM
GetUrWheel
Former Sponsor
GetUrWheel's Avatar
if you want to downgrade to 245.. you 'd want to do 245/40/19.
I, on the other hand, would shoot for 265/35/19 all around.
Old 05-08-17, 10:04 AM
sarmyth
sarmyth's Avatar
You want to make sure the front and rear tires are the same overall diameter. 245/40R19 on all 4 corners is what you'd shoot for if you want your speedometer to be correct =)
At least for Michelin PS4S's the 245/40R19 variant allows for rim sizes between 8-9.5" so your factory rear rims at 9" will fit them without issue.
Bocatrip
09-25-18 09:59 AM
ISFPOWER
RC F (2015-present)
03-14-17 08:37 PM
96ls400ky
06-04-08 07:15 PM
Quick Reply: Square setup?
