Brakes Squeal
Brakes Squeal
hey guys..
I took the car in yesterday for the window motor going bad and had them also look at the squeal from the brakes.. Because I had the car in the garage and didn't drive it for two days.. and when i took it out, the brakes squeal..
here is the tsb..
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=178936
talked to the service advisor, the tsb had been performed and there isn't much to do about it.. is that true? cause the brake squeals is really annoying..
thanks.
here is the tsb..
thanks.
Did they replace brake pads I know it's normal for brakes to squeal when they are new. Otherwise you could try removing the brakes and putting an anti squeal substance on the brake pads, sorry I can not remember it's exact name but it should get rid of the squeal.
Note my brakes only squealed for the first two months I had the car and then for a week after I changed the pads.
