Has anyone done an after market sub and amp install??
#46
I have the ML amp, does anyone know which wire are the front door (left/right)?
I've already tapped the subwoofer but my automatic LC2i turn on and off to the tune of the subwoofer. I would like to tap the doors to keep it on and also may take the door signal rather than the subwoofer so that I can get full signal.
ML amp wire 2013 gs 350
under side of ML sub
ML sub cover removed. Passenger side lead is positive
#47
2013 Lexus GS 350 DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts black (60A) + driver dash fuse box, white 1 pin plug (5E), pin 1
Second 12 Volts blue (80A) + passenger dash fuse box, wht 1 pin plg (4E), pin 1
Starter purple (SS1), green (SS2) - Engine Switch, black 10 pin plug, pins 5 and 1
Also found purple - green (-) at the Certification ECU behind the glove box, white 30 pin plug, pins 28 and 30.
Second Starter lt. green + Certification ECU behind glove box, white 18 pin plug, pin 5
Ignition black + Certification ECU behind glove box, white 18 pin plug, pin 9
Also found black (+) in the passenger kick, blue 22 pin plug, pin 5.
Second Ignition black + Certification ECU behind glove box, white 30 pin plug, pin 6
Third Ignition N/A
Accessory black + Certification ECU behind glove box, white 30 pin plug, pin 4
Second Accessory N/A
Third Accessory N/A
Keysense N/A
Data Bus yellow (RX), white (TX) data Engine Switch, black 10 pin plug, pins 8 and 7
The immobilizer light is lt. green at the Certification ECU behind the glove box, white 30 pin plug, pin 18. The IMO - IMI wires are pink - lt. green in the driver kick, white 64 pin plug, pins 35 and 36.
Can Bus High green data data link connector, black 16 pin plug, pin 6
Can Bus Low white data data link connector, black 16 pin plug, pin 14
Can Bus Sw N/A
Power Lock use factory alarm arm
Power Unlock use factory alarm disarm
Lock Motor green 5 wire driver dash fuse box, white 48 pin plug (5C), pin 9
Driver Unlock Motor blue 5 wire driver dash fuse box, white 48 pin plug (5C), pin 10
Passenger Unlock Motor lt. green 5 wire driver dash fuse box, white 48 pin plug (5C), pin 12
Parking Lights (-) black - Body ECU, white 30 pin plug, pin 30
The Body ECU is attached to the right side of the driver dash fuse box.
Parking Lights (+) green + driver kick, harness to rear
Hazards pink - hazard switch, white 16 pin plug, pin 9
Turn Signal (Left) yellow + driver dash fuse box, white 48 pin plug (5C), pin 5
Turn Signal (Right) green + driver dash fuse box, white 48 pin plug (5C), pin 2
Headlight lt. green - Body ECU, white 30 pin plug, pin 29
AutoLights red (interrupt to turn off autolights) - Body ECU, white 30 pin plug, pin 28
Reverse Light red + driver kick, harness to rear
Left Front Door Trigger red - driver dash fuse box, white 48 pin plug (5C), pin 44
Right Front Door Trigger red - dr dash fuse box, rear, wh 64 pin plg (5A), pin 33
Left Rear Door Trigger green - Body ECU, white 18 pin plug, pin 3
Right Rear Door Trigger green - Body ECU, white 30 pin plug, pin 6
Dome Supervision lt. blue - driver dash fuse box, rear, white 64 pin plug (5A), pin 27
Trunk/Hatch Pin pink (without power trunk opener and closer) - Body ECU, white 30 pin plug, pin 19
The Body ECU is attached to the right side of the driver dash fuse box. On vehicles with power trunk opener and closer, it is gray (-) at the luggage closer motor in the left side of the trunk, white 26 pin plug, pin 20.
Rear Glass Pin N/A
Hood Pin gray - driver dash fuse box, white 32 pin plug (5D), pin 28
Trunk/Hatch Release yellow - Body ECU, white 28 pin plug, pin 8
Trunk Release Motor black (without power trunk opener and closer) 5 wire passenger dash fuse box, white 32 pin plug (4D), pin 18
Fuel Door Release (unlocks along with driver door)
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm gray (driver door key lock) - Driver Door Module, white 24 pin plug, pin 16
Factory Alarm Disarm purple (driver door key unlock) double - Driver Door Module, white 24 pin plug, pin 24
Disarm No Unlock Smart Key and ignition
Trunk Alarm Shunt lt. blue (trunk key cylinder) - passenger kick, white 67 pin plug, pin 24
Tachometer gray ac data link connector, black 16 pin plug, pin 9
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal N/A
Fuel Pump blue + driver kick, harness to rear
Rear Defroster black - passenger kick, gray 22 pin plug, pin 3
Mirror Defroster (CAN bus)
Left Front Heated Seat pink + driver kick, white 67 pin plug, pin 34
Right Front Heated Seat white + passenger kick, white 67 pin plug, pin 47
Speed Sense lt. blue ac radio, wht 59 pin plug, pin 56 or driver kick, wht 26 pin plug, pin 25
Brake Wire red + brake switch, white 5 pin plug, pin 2
Parking Brake (electric parking brake)
Horn Trigger pink - driver dash fuse box, white 32 pin plug (5D), pin 10
Wipers gray (LO), pink (HI) - driver kick, white 26 pin plug, pins 1 and 15
Left Front Window (Up/Down) use factory alarm arm/disarm
Right Front Window (Up/Down) see left front window
Left Rear Window (Up/Down) see left front window
Right Rear Window (Up/Down) see left front window
Sun Roof (Open/Close) use factory alarm arm/disarm
Sun Roof (Limit/Close) N/A
Memory Seat 1 black - Driver Door Module, white 26 pin plug, pin 22
Memory Seat 2 lt. blue - Driver Door Module, white 26 pin plug, pin 23
Memory Seat 3 purple - Driver Door Module, white 26 pin plug, pin 24
Radio 12V blue + radio, white 59 pin plug, pin 17
Radio Ground white/black - radio, white 59 pin plug, pin 12
Radio Ignition gray + radio, white 59 pin plug, pin 16
Radio Illumination green (parking lights), white (dimmer) +,- radio, white 59 pin plug, pins 14 and 13
Factory Amp Turn-on (MOST bus)
Power Antenna N/A
Left Front Speaker (+/-) pink - red (door); white - red (dash) +,- amplifier, white 30 pin plug, pins 4 and 19; 12 and 27
The amplifier is in the right side of the trunk.
Right Front Speaker (+/-) lt. green - blue (door); red - pink (dash) +,- amplifier, white 30 pin plug, pins 5 and 20; 13 and 28
Left Rear Speaker (+/-) black - yellow (door); lt. green - blue (surround) +,- amplifier, white 30 pin plug, pins 14 and 29; 10 and 25
Right Rear Speaker (+/-) red - white (door); black - yellow (surround) +,- amplifier, white 30 pin plug, pins 15 and 30; 11 and 26
Center Channel (+/-) yellow - black +,- amplifier, white 30 pin plug, pins 7 and 22
Subwoofer (+/-) red - white +,- amplifier, white 30 pin plug, pins 6 and 21
Aux. Audio Input Left (+/-) black - red +,- radio, white 16 pin plug, pins 8 and 15
Aux. Audio Input Right (+/-) white - red +,- radio, white 16 pin plug, pins 7 and 15
RSE Video (+/-) red - white (rear view camera video) +,- radio, white 59 pin plug, pins 18 and 19
RSE Audio Left (+/-) N/A
RSE Audio Right (+/-) N/A
Satellite Radio 12 Volts N/A
Satellite Radio Ground N/A
Satellite Radio Ignition N/A
Satellite Radio Antenna N/A
Satellite Audio Left (+/-) N/A
Satellite Audio Right (+/-) N/A
Item Size Depth Location
Headunit irregular center of dash
Left Front Speaker 7.0 or 6.6 x 9.8 left front door
Left Front Tweeter 3.5 left front dash
Right Front Speaker 7.0 or 6.6 x 9.8 right front door
Right Front Tweeter 3.5 right front dash
Left Rear Speaker 6.2 or 6.6 left rear door
Left Rear Tweeter 0.9 (tweeter); 3.5 (surround) left rear door; left rear deck
Right Rear Speaker 6.2 or 6.6 right rear door
Right Rear Tweeter 0.9 (tweeter); 3.5 (surround) right rear door; right rear deck
Center Channel 3.5 top center of dash
Subwoofer 9.8 top center of rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner (built into radio)
All Products
Third Ignition N/A
Third Accessory N/A
Keysense N/A
Can Bus Sw N/A
Rear Glass Pin N/A
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal N/A
Power Antenna N/A
Left Front Headrest
Left Rear Headrest
Right Rear Headrest
#48
The OEM amp is located under the right side panel of the trunk – this is where you will connect the LOC. Use the amp 30 pin plug to tap into the red (+) and white (-) wires at pins 6 and 21:
http://www.the12volt.com/installbay/...asp?tid=132844
DO NOT CUT these two wires, just splice them and tape the LOC wires to them per the instructions provided with your LOC. I used an old LOC that I had, but the installation should be mostly the same for others – below are the instructions that I followed:
http://www.rockfordfosgate.com/rftec...CAULOC-MAN.pdf
#49
In the first picture below, I used the white wire on the small harness (harness closer to the rear of the car/amp). I spliced the wire further up from the actual plug as I didn't want to cut/mess with the foam guard around the wires (2nd photo - where the electrical tape is).
Chaos236 (06-28-20)
#50
Adding amp with integrated speaker level inputs
First post, previously just a troll lurking to get great info here. I'm adding an amp to a 15 GS F Sport w/o the ML. I have the Alpine MRV-500 that has integrated line level inputs. I saw the advice to connect to the sub out on the factory amp. I noticed that folks reference connecting to wires 6 and 21. Do I only need to connect one channel in to the amps integrated LOC?
Thanks in advance for any advice!
#52
You should be ok just tapping the sub out on the amplifier. The subwoofer signal has pretty good coverage of the bass range, see post below for an RTA analysis of the signal coming out of the amp. If anything, you could introduce a DSP to refine the output further.
https://www.clublexus.com/forums/is-...ml#post9409890
#53
The amp supports line level stereo in, but is mono out. It's okay to just have the one channel of line level inputs in? I'm just confused as to why they'd take a stereo signal in to drive a mono sub.
#54
Yeah that's not a problem. The amp will downmix the stereo into a mono output for the subwoofer.
#56
Sam - I just traded my 2015 Crafted Line in for the 2017 GS350 and installed the sub again. I went ahead and took your advice and did a little more research. I was able to find the remote wire on the stock amp in the trunk and use that for the aftermarket sub instead of running a wire from the fuse box on the passenger side.
thanks
DaPope10
08-25-15 01:13 AM
Mayur Patel
08-30-01 05:19 PM
