F Sport Brake Replacement
Yep I helped my friend with a 15 F Sport put on the drilled Stop Sport Rotors and Akebono pads. Cleaned the crap out of everything and used Synthetic brake lube everywhere. We did go back and do a Bleed with the scanner, and it firmed them up some more better than stock. Been a year now and never ever squeaked again.
Akebono are of very, very high quality and they last a long time. I run the Akebono Performance series compound on mine and they don't fade at speed and stop like crazy.
https://akebonobrakes.com/performance-street
Need mine done too. I'm going to call Toyota tomorrow to see what they say the cost is? I don't know why every 4th Gen GS I see under the hood always looks like it the brake fluid is dirty and needs changing.
Is your GS a F Sport?
Yes. Too much dust from the original pads is the only reason I changed them.
I have heard good things about the EBC Ultimate pad. Compound Supposed to be OEM spec. Just saying. I have some NAPA high end pads I installed months ago. They actually don't squeak at all. I installed with pepper grease in proper contact points and back of pad. But man, they sound like crap. No squeak just terrible grating sound. Almost like metal to metal but there not.
I am happy for anyone who has good luck with whatever pad they use. I used Textar, one of the very best pads money can buy. Squealed like a pig!
Lexus did not create the TSB for fun, ya know.
Please post your posts.
Again, good luck.
Again, good luck.
Anyway, are those NAPA pads semi metallic or ceramic? I used to use semi metallic pads a life time ago when money was tight, and those ones were the "best" I could afford and I can still remember the metal to metal grinding noise. Hated it.
Since you live in CO, you will be the ideal person to give us all a feedback about the non-OEM ones and squeaking. In majority of cases, or at least in my case, the squeaking only happens when the temps dip low, but only for the first 10 or so yards. On warmer days, say 50+ degrees, like it was this morning here in MD, there is no squeaking from the factory installed OEM pads.
Great timing on this post. My wear indicator has been squealing at me and the dealer confirmed I need new pads and recommended turning the rotors. To me this sounds like the perfect opportunity to replace pads and rotors myself instead. Where are we buying OEM parts these days? Not wanting to go aftermarket for anything on this car, at least, not yet.
https://www.belllexusnorthscottsdale.com/
gringle77
Mar 7, 2019 12:10 PM
