HELP 13 gs 350 450h headlights
@Lfig402 It will fit - but its not plug/play...read through these threads/posts below (you'll need a new headlamp ECU and possibly re-wiring for the AFS):
https://www.clublexus.com/forums/gs-...l#post10054152
https://www.clublexus.com/forums/gs-...l#post10298054
The led headlamp plugs are the same as the hids, however the hids share the same ground between the low beams and high beams where as the leds are separate. If your GS is a luxury model, it is plug and play. If you have an f sport (like me), you would need to splice the ground pins on the leds together in order to get the high beams to work
Lfig402 (11-24-21)
initial
08-07-21 11:45 PM
