F-Sport/Base springs vs GSF
I’ve been in the market for lowering springs I was wondering if the GSF springs or just a different spring right or if they are actually lower. Had the thought to just put those in my F sport instead of going with aftermarket if it was what makes the GSF suspension different from an F sport. I did look up the parts and I know that they are a different part number from the base model and F sport. Just don’t know what the difference in spring rate is and or height. Almost inclined to just order those instead of Swifts or RSR‘s
what all makes the GSF suspension different? Is it everything from spring rates, coil spring height, dampers and sway bars and LCA bushings?
Sorry, I wish I could help.
I got $150 springs from ebay which are a bit more stiff than factory F-sport RWD and have not had any regrets....
I'll eventually get the rear camber sorted out to save some rear tire inner wear....
I would go lower eventually....
F Sport and GS F suspension part numbers are totally different.
Nezumi
Suspension and Brakes
06-10-10 11:47 AM
