Does anyone know if these spacers will work on my RCF wheels? This is what the hub looks like on the back. I’m curious if those pockets are big enough for the stock studs to go into. Thanks
Factory studs are about 25mm long. With the 15mm bolt-on spacer installed, the factory studs protrude 10-11mm. Measure the depth of pockets, if they're deeper than 12-13mm you're good. Those seem deep enough as far as I can tell.
