How do I use this car charger?
Hi there. I have a 2013 gs 350 AWD F Sport
https://imgur.com/a/oK4l3tF
It says determine which post is grounded.. Which one would that be? And also where would I clip the other one? Is the side of the hood ok? I don't want to scratch it. Also how long do I charge it for? Sorry I'm a complete newbie with this. I can provide more info from the instruction manual or my car battery if need be. Thank you!
This is a trickle/maintainer charger. Red clip goes to positivities/+/red side of battery. Black clip goes to negative/-/black side of battery. The red plus sign above the battery post on the right is positive.
The following 2 users liked this post by swfla:
Im2bz2p345 (04-21-20),
mikepgs350 (04-21-20)
I've just never had to fix anything on a car before. Knock on wood this car has been completely problem free. I've taken apart a few washing machines but have never had a battery die on me. Will the light change from orange to green when it's charged? How long do you think? 1-2 days?
mikepgs350 (04-22-20)
After a drive, it went from orange to green in less than an hour.
Did your battery die on its own?
You may have the faulty network module we were talking about here. Lexus TSB.
Re the maintainer: the clip connectors made me nervous, felt much better bolting directly to the terminals.
The following 2 users liked this post by jonathancl:
Yes it died on it's own after not starting it for 7 days. I've gone 10 days before and never had this happen (although they were weak starts). The battery is at least 5 years old. If i have the faulty module is a no charge fix/recall? Thank you!
Why don't you just replace your old, worn out dead battery? And, return the battery maintainer you bought thinking you could somehow save the life of your old, worn out dead battery...
The store won't take it back because of Covid-19 and it was the only place walkable. Yeah I bought the wrong item but it was only $50 and I should actually be using something like this for when I do go away for 10ish days at a time. I'd probably have to pay $40 to get a boost for a drive to the dealership anyway. Thank you for being so concerned with my decision making process lol.
Your best bet would be to go to Princess Auto or whatever store is near you and have them do a battery test. It might be free! If the battery is bad, or even just borderline, replace the battery. Since it's more than 5 years old, it's at the end of its useful life. Don't try to squeeze a couple more months out of a weak battery because it will fail at the worst possible time and you'll get stranded.
that's what I was planning on doing. seeing if i could stretch it out to when I need an oil change but you make a very good point. I can just check this with a multimeter right? I don't mind buying one of those, it would have came in handy when I was taking apart my washing machine.
If you keep spending money on chargers and multimeters you could have replaced your old, worn out dead battery with a brand spanking new one you wouldn't have to worry about for years to come.
To get an accurate test of the health and condition of your battery you need to have the battery 'load tested'. When a battery is load tested a heavy load (amperage) is drawn from the battery and it is determined how quickly the battery recovers. Most auto stores that carry batteries have a load tester they can use to test customer's batteries at no charge.
