GS2013, Vents/AC issue
I went to a technician and did a reset programing it worked for few days and get back to the same issue. after checking the many technicians, they asked my to change some parts but they still not sure after changing the part the car would work. the parts name "SERVO SUB-ASSY, DAMP "
please if you have had the same issue and you know how to solve it please do share
Thank you and waiting your experience with lexus
You can buy access to the software or acquire it yourself, you will also need a suitable obd2 cable.
These servo units are rather delicate and can easily become damaged when one or more of the multiple plastic reducer gears (worm and spur gears) become unmeshed or broken, or the unit's plastic pivot arm that opens/closes the damper door becomes jambed. Most of the time the culprit is the little worm gear that is mounted on the tiny motor's shaft breaks. This problem exists in different car brands and models, not just Lexus/Toyota.
Some DIY owners (with cars out-of-warranty) have elected to try to repair/fix the damaged servo unit - some successfully, and some not. I think the price of a new servo unit is around $150 to $200. I've heard that some labor (only) estimates have been as high as $800 to replace the unit. I feel sure that some models are a lot more labor intensive to replace the unit than others.
Typically, you will hear the clicking/grinding noise when the temperature is colder or warmer than your vehicle's system is set...and when the vehicle's inside temperature comes close to matching the desired temperature (or when the outside temperature matches the desired set point temperature) it will start making the noise - in other words for example, the car's HVAC temperature is set on [say] 72° and the car's inside temperature is (or has become) ~72° and the outside ambient temperature is about the same at ~72° - this is when it reaches the (thermostat) threshold and the servo motor receives signal voltage to operate the damper door....but the gears are locked-up so you get a clicking or grinding sound.
The air mix servo motor unit is located behind the dashboard near the center, beside the duct work that feeds air to the supply outlets.
This is what a typical air mix servo motor unit looks like...
