Any brands/suggestions for paint to buy? All but decided on the burnt copper. My mechanic had red if I went that, pretty sure he won't have this though.
Links?
The only high temp copper/burnt copper spray is from VHT. I looked for others and could not find it, I kind of wish it was a little more metallic but it looks pretty good.
Yes, one can should be plenty, the rears are a little tricky, if you are leaving the calipers on you may want to de cant a little so you can brush it on in some of the hard to get crevices.
I used about 1 1/2 cans to do mine. So to be safe get 2 cans. Also if you planning on adding decals wait at least a day or more as I messed up one side by rushing to put them on like 2 hrs after and the paint had not cured enough. Ended up having to spray paint on a plate a use a brush to touch up the spots where the paint started lifting when I was placing the decal..I added the high temp clear a week later once the paint had fully cured.
can't say I've ever seen red calipers on a red car.
Originally Posted by NickMayer
But none of those look like GS's 😉
So, after saying you've never seen red calipers on a red car...now you want to get specific about the details! Does the GS have to have certain wheels or tires on it to qualify? . . .
Originally Posted by jonathancl
Can't say I've ever seen a red car...
It's a good thing BC up there is here for you then! 😁
I'm told that cars are available in different colors in case more help might be needed.
So, after saying you've never seen red calipers on a red car...now you want to get specific about the details! Does the GS have to have certain wheels or tires on it to qualify? . .I'm told that cars are available in different colors in case more help might be needed.
I think his question is valid... none of those cars are the same color as the Matador red of the GS, right?
Matador red and a brighter typical Brembo red brake caliper might clash; would be a good idea to see it in advance. In my head I don't think it would look good, most of those (non-GS) pictured above have close-to-matching colors. I'd go with black or gold.
I believe I said, "does anyone have examples of a red GS with red calipers." 😉
Then I went on to say I've never "seen" a red car with red calipers. You know, with my own eyes. I am aware of Google, but thanks for being so helpful.
But please, continue on being the BC we all come to have known 😁
