Safe front Caliper to wheel Clearance?
Old Apr 9, 2019 | 02:09 PM
peasodos's Avatar
peasodos
Default Safe front Caliper to wheel Clearance?
For our cars what would you say is a minimum Caliper to wheel Clearance for the front wheels?
It's only the front edge of the caliper that's close to the wheels, everything else has plenty of space.
Old Apr 9, 2019 | 05:12 PM
AJLex19's Avatar
AJLex19
I'm going to say 5mm because i'm overly cautious about wheel/tire related changes...but you will probably be able to get away with having as little as 2-3mm clearance. I don't know what the stock clearance is on our wheels! (i have stock 18s).
Do you know what the stock clearance was vs. the new wheel clearance?
Old Apr 9, 2019 | 05:57 PM
baconRx's Avatar
baconRx
3mm its what brembo kits recommend so hopefully you got that
Old Apr 9, 2019 | 07:03 PM
peasodos's Avatar
peasodos
I checked with a couple shops and they said 2mm minimum is safe. When they first put on the wheels and tried to back the car it shaved the front edge of the caliper.
I'm getting 3 mm spacers since they are still safe with oem studs and will shave that edge of the caliper when I repaint it later this year. I never thought to check the clearance prior to install because I assumed since it was a OEM lexus wheel it would be fine, but I guess the ES calipers are much smaller.
Old Apr 10, 2019 | 07:51 PM
waygreen's Avatar
waygreen
These guys have a handy calculator that may be helpful if you can chase down the variables:
http://www.tceperformanceproducts.co...per-clearance/
I never measured it but the clearance on my '18 STI was very small. I would guess 2mm, 3mm max which seems to jive with some of the comments above given it had giant, 6 piston brembos.
FIGS
RC F (2015-present)
18
Dec 1, 2016 12:41 PM
myLEXsc400
Jan 20, 2016 10:29 AM
sraesmit
RC F (2015-present)
Jul 8, 2015 05:22 PM
Low Life
Nov 25, 2012 02:07 PM
AZ IS350
Suspension and Brakes
Sep 23, 2006 10:24 AM
